rear end change out - JeepForum.com
post #1 of 7 Old 01-28-2013, 10:15 PM Thread Starter
frhrwa
Fish'n Fool
frhrwa's Avatar
rear end change out
does the 8.8 bolt right up to the CJ-7 (1984)? or do you have to move the perches? or is there a better rear end that will bolt up.. I have to find one with 4:10 to match the front.. my 20 has a locker and 4:10 now.. but want the disc brakes on the rear..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #2 of 7 Old 01-28-2013, 10:57 PM
82JeepCJ7
1982 CJ7
Do a disc brake conversion. Much simpler than a axle swap. Plus the 8.8 has the wrong bolt pattern.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 7 Old 01-29-2013, 07:51 AM
CSP
The 8.8 is also quite a bit wider. There are no bolt in axles other than another CJ axle.
CSP is offline
post #4 of 7 Old 01-29-2013, 08:02 AM Thread Starter
frhrwa
Fish'n Fool
frhrwa's Avatar
I thought ford and Jeep, and dodge for that matter had the same bolt pattern?
frhrwa is offline
post #5 of 7 Old 01-29-2013, 08:04 AM Thread Starter
frhrwa
Fish'n Fool
frhrwa's Avatar
moving the spring perches and rewelding is no big deal, but if its too wide then shortening the axles and tubes, gets more involved ($$$).. would rather have something the right width, and move the perches..
frhrwa is offline
post #6 of 7 Old 01-29-2013, 08:15 AM
CSP
The only 8.8 with disc brakes is the one found under Ford Explorers. Explorers and Rangers use the smaller 5 on 4.5" pattern. It's only the half-ton pickups and Broncos that are the same 5 on 5.5" as CJs.
CSP is offline
post #7 of 7 Old 01-29-2013, 08:21 AM Thread Starter
frhrwa
Fish'n Fool
frhrwa's Avatar
see, now that's what I like about this forum, I learned something new, and I didn't get dirty or greasy finding it out.. thank you.. good info to put in my notebook... "I love this greaseless, painless, knowledge bank".. although, someone at sometime got dirty, busted knuckles in order to give us this info..
frhrwa is offline
