#1 | |
rear drum swap
Does any body know if I can put the larger drum brake off a 76 cj narrow axle onto a wide track axle from a 86 cj. I'm gonna be diving into the project soon-just looking for quick answers so I can order parts.
#2 |
GROUND POUNDER
As long as the 86 has the AMC 20 rear axle and you use the 11" backing plate/brake hardware it shouldn't be a problem. It's not the 86 D44 is it?
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#3 | |
The 86 Dana 44 uses the same brakes as the amc 20. This was just for the 86 d44 though.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage "when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp" |
#4 |
GROUND POUNDER
I wasn't sure if they shared them or not..
#5 |
Also, the emergency brake cables are different for the 11" backing plates.
Jeep #1 = 76 CJ5, 304, T18, Twinstick Dana 20, Lock-Right in front, Yukon HD front axles, One piece axles - Detroit Locker in rear, 2.5" Rancho Springs, 1" lift shackles, 32x11.5 Super Swamper TSL/SX, Warn XD9000i, York OBA. Jeep #2 = 80 CJ7, 401, T18, D300, 3" Black Diamond Lift, TrXus M/T 33x12.5, Yukon 1 piece axles, Auburn posi in rear, Detroit TrueTrac in front, Ramsey 8000. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
