#16 | |
Here's a pic of mine after I just replaced the shoes, drums and the auto adjust cable that was missing. As Bard mentioned, there are some parts that aren't in that kit. Some PB Blaster on the auto adjuster loosened my stuck one right up. Good luck.
http://www.flickr.com/photos/22906308@N03/2449271427/
#17 |
aka Mike
I did cylenders, shoes and drums when i bought mine.... 2 months later i was doing springs and self adjusters.....
if in doubt... change it out....
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 33x10.5x15 BGF TA KO on Crome Modular rims. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX. Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love. http://main.nationalmssociety.org/site/TR/Walk/VABWalkEvents?px=6419856&pg=personal&fr_id=18331 |
#18 |
I just replace the shoes on all 4 wheels on my 1976 CJ and the best advice I can give you is spend the $20.00 or $25.00 bucks and buy the proper brake changing tools to do the job. The spring pliers etc.. It will make the job and you knuckles so much happier.
#19 |
If you are going to all that work why not just convert the rear to disk now? Made a huge difference in my 76 CJ7that originally had the larger 11 inch rear drum brakes. Still have the rear 11 inch drums if somebody needs them.
Jim |
#20 |
Another note, as jfwireless said. he had the larger ones. There are actually two sizes of drum and of course I got the wrong size to start. The shoes come in 1.5 and 2" widths.
#21 | |
Underground Jeeps
And the kits are kinda outta my ballpark right now.
Mike 1986 Jeep CJ7 (photos) Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work |
#22 | |
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed. |
#23 |
2x's on this. You can do this job with out brake tools, but for the love of God, just get them. They are worth every penny. Also DO NOT TEAR BOTH SIDES APART AT THE SAME TIME! This way you can look at one side together to see where everything should go. Goodluck.
#24 |
Well, I just got done rebuilding my drums last night after getting the new Moser axle shafts in. It's really not that bad, I hadn't even done Jeep brakes in a while. I even ended up having to toss all my brake parts in a pile in my garage because it started raining the other night while I was trying to finish, so putting them back together was like a frigging puzzle. If you have any questions let me know. I also have a diagram (similar to what Bard posted) in my Chilton's if you want me to scan it for you when I get home tonight. Really the hardest part is working with those damn springs. I didn't use any special tools. I just used a screwdriver to pry those springs on and off, and then when that didn't work a pair of vise grips clamped on real well made it possible to pull them back on.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress) 1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress) |
#25 | |
Nothing could be farther from the truth in regard to the braking improvement on my CJ. The real improvement is when the brakes are wet, you can stand on drum brakes when wet and still crash into that car in front of you. It really rains lots down hear on South Florida, and after the past three hurricanes running through 2-3 feet of water constantly you really appreciate the disk brakes. When you lock up the front, you get more than 25% from the rear. I do not believe that 75% number on my CJ7. I have the Suzuki rotors and 300ZX calipers, do not knock it until you experience it. It worked out really great. Jim |
#26 |
good info...
#27 |
If possible... switch to rear disc...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
