Rear drive shaft angle? - JeepForum.com
post #1 of 13 Old 03-31-2012, 05:51 PM Thread Starter
Ollie09
1983 CJ7
Does the angle of the rear driveshaft on my 83' CJ7 look correct? Seems kind of steep. There is no body on it so I assume it will come down a little with the added weight but this just doesn't look right.
Ollie09 is offline
post #2 of 13 Old 03-31-2012, 05:55 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Looks kind of steep to me too. Have you used an angle finder to determine how many degrees of deflection on the u-joint?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 13 Old 03-31-2012, 05:55 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Your gonna need a CV shaft.
It'll come down a little when its all back together, but not what you need.
I'd recommend looking up Tatton drive shafts on ebay-
Here ya go.
http://www.ebay.com/itm/JEEP-CV-DRIV...#ht_2259wt_803
don't order it until your nearly all reassembled.
You'll also need to point the pinion 2 lower than the T-case output yolk.
LT1CJ7 is offline
post #4 of 13 Old 03-31-2012, 06:08 PM Thread Starter
Ollie09
1983 CJ7
I,d recommend looking up Tatton drive shafts on ebay-
The suspension is all original and stock stuff. I'm doing a frame off, with no modifications. I don't remember it being this steep when I took it apart, but I didn't pay much attention to it.
Ollie09 is offline
post #5 of 13 Old 03-31-2012, 06:15 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
If it's not NOS, then it's not original parts.
Maybe set 250-300 lbs on the rear cross member and see what your angles are.
That looks extremely steep for stock replacement parts.
Btw, looks like your doing an excellent job on the resto.
LT1CJ7 is offline
post #6 of 13 Old 03-31-2012, 06:28 PM
nitecop
Here is a diaghram of the Proper Geometry For the 2 types of drive shafts.
3 joint drive shaft. (A.K.A. double cardon joint and a single joint shaft)
A shaft with 2 single joints
(photos from Tom Woods Drive shafts)
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #7 of 13 Old 03-31-2012, 06:43 PM
gojeepin
1983 CJ7
For stock springs that looks too high (even for no body weight). Are your suspension components too tight to allow the suspension to move?
If your angle remains that steep, you'll need to angle the pinion up and use a double cardan driveshaft.
I have some better diagrams for suspension, steering, and driveline angles if you want to look at them... link in signature block.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #8 of 13 Old 03-31-2012, 11:27 PM
bbc
Agree, it's too steep.
7* - 12* for traditional shaft.
12* being the max before you have to get yourself into a CV shaft.
And wait till you get the body back on with most of your weight on the chassis to point your pinion up and order the shaft.
bbc is offline
post #9 of 13 Old 04-01-2012, 05:11 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
Here ya go.
X2, love my tattons
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #10 of 13 Old 04-01-2012, 08:13 AM Thread Starter
Ollie09
1983 CJ7
Thanks for the compliment\
The parts are what came on the Jeep when I bought it which was all original. I think maybe I understand what happened. I tightened up all the suspension joints with no weight on it (I know better!!). I will loosen everthing up and not retighten until the body is back on.
Thanks to all.
Ollie09 is offline
post #11 of 13 Old 04-01-2012, 08:15 AM Thread Starter
Ollie09
1983 CJ7
How do I change the pinion angle?
Ollie09 is offline
post #12 of 13 Old 04-01-2012, 08:17 AM
RobsCrawlin7
no balls
to sum it up, cut the spring perches off and reweld em on after turning the pinion up
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #13 of 13 Old 04-01-2012, 08:17 AM
gojeepin
1983 CJ7
Either use degree shims or cut off the old perches to weld new ones at the proper angle.
gojeepin is offline
Drive shaft angle buggycj7 Jeep CJ Forum 7 03-07-2012 10:15 AM
Drive shaft angle / drive shaft length / 2.5 inch lift GlennLever Jeep CJ Forum 6 10-22-2011 03:40 PM
Please comment on this drive shaft angle Splinter Jeep CJ Forum 11 08-03-2010 05:34 PM
Drive shaft angle questions on 84 CJ kev12 Jeep CJ Forum 4 07-07-2010 09:09 AM
CJ-5 rear drive-shaft angle/pitch Ol' Roy Jeep CJ Forum 4 06-22-2005 09:51 PM
