Rear disk conversion - JeepForum.com
post #1 of 3 Old 01-31-2006, 09:24 AM Thread Starter
CJ51973
CJ51973's Avatar
Is there a junk yard solution for rear disk conversion on a drum Dana 44? I have a buddy with a TJ w/44 who is also interested. Everybody would like disc all the way around especially if it was junk yard available.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #2 of 3 Old 01-31-2006, 10:50 AM
Bill USN-1
Not completely JY but close if you are 5 on 5.5!!!
Rear disc
FI Mod
Bill at Hamiltonfuelinjectiondotcom
Bill USN-1 is offline
post #3 of 3 Old 01-31-2006, 11:51 AM
rjcj-8
If you want a bolt on caliper bracket TSM Mfg Co
out of Castle Rock CO makes a bolt on bracket for the D44.
As Bill noted in his writeup an MC change will probably be in order.
I went with yj pb booster and an MC from a mercury grand marque (sp)
It puts the break lines on the engine side of the MC so it will be close to the TBI intake. A better choice would probably be the cj booster with the Corvette mc which will keep the lines on thier stock side.
I had to tweak the stock cj ebrake setup at the load balancer (not the right term)
where the 1 line splits into the left and right line. It would want to put more tension on one side than the other. I put in a piece of round stock for the balancer to pivot on and it has seamed to work well.
rjcj-8 is offline
amc 20 rear disk conversion probs blutowski Jeep CJ Forum 7 07-16-2009 07:54 PM
cj rear disk brake conversion matt02888 Jeep CJ Forum 4 09-09-2008 11:35 AM
Drum to disk conversion trouble molsenice Jeep CJ Forum 3 02-12-2007 04:26 PM
Dana 25,27,30 disk conversion CJ51973 Jeep CJ Forum 4 02-02-2005 09:09 AM
Disk Conversion blytle20 Jeep CJ Forum 3 10-26-2003 07:40 AM
