rear cross member - JeepForum.com
post #1 of 12 Old 08-04-2009, 09:13 PM Thread Starter
jeepcrazy83
1979 CJ7
rear cross member
Hello everyone.
Started my complete rebuild on my 1979 cj7. Got the frame blasted repaired all the bad spots and ready to replace my rear cross member. Mine was pretty well shot! I plan to pull a small trailer and maybe someday and a rear tire carrier.
I need a diagram of a rear cross member to make my new one. Also if anyone has ideas as to what the best way to build one all information will be greatly appreciated.
jeepcrazy83 is offline
post #2 of 12 Old 08-04-2009, 10:23 PM
scottymac62
1979 CJ7
Why build one when you can get buy one ready made for about $100.
http://www.classicent.com/jeep.php
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #3 of 12 Old 08-05-2009, 03:40 AM
Lordwrench
1978 CJ7
Better one for 125$
This one is better,thicker stronger,faster........
http://www.cj-8.com/forum/showthread...ar+crossmember
Lordwrench is offline
post #4 of 12 Old 08-05-2009, 04:57 AM
Tigger01
I would go with lordwrench's Idea if they still have them cause of thickness a little more but looks custom
I did Scottymacks62 suggestion cheaper but didn't look into it myself when I did it Cheaper though
So its a fillip of the coin for you from the both of them
Tigger01 is offline
post #5 of 12 Old 08-07-2009, 07:02 AM Thread Starter
jeepcrazy83
1979 CJ7
Thank for for your replies. I'm really wanting to make my own though. So if any can help with some sort of diagram that would be great. thanks
post #6 of 12 Old 08-10-2009, 08:08 PM Thread Starter
jeepcrazy83
1979 CJ7
No one has any measurements or diagrams ??. Does anyone have measurements, etc for the gas tank bracket just in front of the gas tank? mine was gone when i got the jeep. thanks for any help.
post #7 of 12 Old 08-10-2009, 08:13 PM
jeepinarkansas
1982 CJ8
they were both $100
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
jeepinarkansas is offline
post #8 of 12 Old 08-11-2009, 06:01 AM
fuzz401
1978 CJ7
I made mine out of stainless steel
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #9 of 12 Old 08-11-2009, 04:53 PM Thread Starter
jeepcrazy83
1979 CJ7
i got a rear cross member made. Now does anyone know if the body mounts on the rear cross member the same distance for a yj as the cj7? As I'm putting the yj tub on my cj7 frame.
Also still need any help with the bracket in front of the gas tank.
post #10 of 12 Old 08-11-2009, 06:17 PM
paraman72
If I recall that was the mount that was different. There was a write somewhere about the yj to cj tub conversion. Do some searching and it will come up.
85 CJ7 Build in progress, 258 with T-5 and dana 300.
Fiberglass tub Raptor lined interior, rustoleum lined the underside. Modified family roll bar from fender mounted rollbar. Full tie ins to the frame soon to come.
paraman72 is offline
post #11 of 12 Old 08-12-2009, 10:17 AM
scottymac62
1979 CJ7
I just did the same YJ swap. You will need to move your cross member body mount holes outboard by 3/4" each to get them to line up with your YJ tub.
post #12 of 12 Old 08-13-2009, 06:44 AM Thread Starter
jeepcrazy83
1979 CJ7
thanks scottymac.
Soft spot at rear cross member-Repair Question jpd1899 Jeep CJ Forum 1 01-24-2010 03:24 PM
Transmission Cross member jmna Jeep CJ Forum 9 12-28-2008 04:26 AM
Cross member EDs Jeep Jeep CJ Forum 4 07-04-2008 08:01 AM
Frame cross member rosco96 Jeep CJ Forum 0 08-06-2007 05:17 AM
Rear-frame cross member replacement certifiablejeep Jeep CJ Forum 0 10-13-2002 09:15 AM
