rear brakes hate them - JeepForum.com
post #1 of 11 Old 09-28-2011, 05:01 PM Thread Starter
kdjc1912
1980 CJ7
Ok hear goes I got a 80 '7 one of
the rear wheel cylinders is leaking. I got the three screws out. Does the dust cover have to come off also. I hate rear brakes with a passion. I have pb blasted the crap out of this thing. Which way do you turn the star wheel up or down to loosen up the brake shoes.
kdjc1912 is offline
post #2 of 11 Old 09-29-2011, 06:27 AM
wkp
1980 CJ7
Take the wheel off and remove the drum. If you are not familiar with removing brakes, take a pic of the the brake shoes and spring arrangements before you take anything apart. It will help to make sure everything goes back together correctly. After removing the drum, remove brake shoes and springs to allow access to the wheel cylinder. You shouldn't have to turn the star wheel to remove brakes, just remove the springs that hold all in place. Springs can usually be removed with a good pair of Vise Grips. Once brake shoes have been removed, disconnect brake fluid line going into back of wheel cylinder. It can be very difficult to loosen this line without damaging the brake line itself. Worse case, you will have to also replace that section of brake line. Then remove the bolts ( from the rear ) that hold the wheel cylinder in place. From there, bolt in new wheel cylinder and put everything back in place. You will have to bleed that wheel when you are finished to remove air from the line and new cylinder. Hope this helps.
wkp is offline
post #3 of 11 Old 09-29-2011, 06:57 AM
bamasteeler
Do you have any kind of manual to start off with?? At minimum go to parts and get you a chiltons or Haynes manual for your jeep.
There are also links around here to online manuals, although they may be for other year models, majority of content is same for cj's.
As for which way to turn self adjuster....if your wheel gets tighter and won't spin....go other way!!! Can't think off top of my head actual direction. Then hope your drum comes off, my right one I have to use a pneumatic rivet gun to get it to come off.
Also google rear brake removal on you tube, am surprised everyday at the videos on there.
1980 Jeep CJ7
AMC 258, T176, D300,
AMC 20 REAR, D30 FRONT
1999 XJ CLASSIC
RC 3" front AAL rear
bamasteeler is offline
post #4 of 11 Old 09-29-2011, 07:20 AM
stodg73
1979 CJ5
To release the brakes, you can turn the star wheel one way really easy, trying to turn it the other way is really hard due to the adjuster linkage.
If it turns easy both ways, then turn it one way about 10 movements and then see if you can spin the drum. If it is rubbing, you need to turn it the other way.
Hope this helps.
'79 CJ5, 258 c.i., Carter BBD, T-150, Dana 20, Dana 30, AMC 20, 33x12.50x15, 3" body lift, taking it back to stock, then tearing it apart and putting it back together again!
stodg73 is offline
post #5 of 11 Old 09-29-2011, 07:30 AM
waterdowg
Here is the Chilton Manual online. It will cover all years all vehicle. Free
http://infotrac.galegroup.com/itweb/mode19592?db=chll
ID Number to access: 0210374362
waterdowg is offline
post #6 of 11 Old 09-29-2011, 08:30 AM
foggybottombob
You can never be sure that someone did not put the adjusters in on the wrong side. Normally you turn the wheel up when adjusting through the backing plate to expand the shoes. I have seen some wheels where it goes the other way but this is not typical. When turning that wheel in the direction of expanding the shoes, you will hear the self adjuster click against the notches on the wheel. When you turn the wheel to loosen the shoes the adjuster should catch on the wheel and not let it turn unless the parts are worn out. So to loosen the shoes you might have to hold the bar which catches the notches on the wheel away from the wheel with a screwdriver so you can turn the wheel that way.
foggybottombob is offline
post #7 of 11 Old 09-29-2011, 08:32 AM
JeepHammer
Running On Empty...
1973 CJ5
I have to disagree,
Take Picutures of EVERYTHING FROM ALL ANGLES!
Remember, there is a 'Left' and 'Right' set of parts, and they don't interchange,
Others you can swap from side to side with no problems.
Brakes are easy once you figure out how they work, so spend some time messing with them so you understnd how they work, then it won't be an issue next time.
The adjuster ALWAYS moves 'UP' to tighten the adjuster, but again, the adjuster and adjuster lever have a right and left set, so if you get them on the wrong side, it won't work and it will drive you nuts until you get them on the correct side.
Some parts aren't marked, so That's a good reason for the pictures of everything.
Leaving one side assembled (If it's working and the parts aren't laying in the bottom of the drum or missing from the last PO or two) will show you how to assemble your parts...
It's usually the adjuster cable & linkage that drives people to the point of lighting a match to the entire project, but people seem to be missing the E-brake transfer bar at the top much of the time for some reason I can't explain...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #8 of 11 Old 09-29-2011, 09:18 AM
John Strenk
John Strenk's Avatar
1976 CJ5
This is kinda what Foggy talks about holding up a bar with a screw driver.
Get one of those adjustment wrenches. They do work great!
John Strenk is online now
post #9 of 11 Old 09-29-2011, 10:27 AM
CJ7ROB
Convert to discs.....
jus' kidding
CJ7ROB is offline
post #10 of 11 Old 09-29-2011, 12:11 PM
Coiz
1979 CJ7
Here is a visual reference to help.
Mike
Coiz is offline
post #11 of 11 Old 09-29-2011, 12:13 PM
hp_lovecraft
1981 CJ5
Originally Posted by JeepHammer View Post
I have to disagree,
Leaving one side assembled .......
One trick that works for me is that as I take apart the drum parts, I set each piece inside the drum (on the ground) roughly where it would be when installed.
Then work in reverse, pulling the parts from the drum.
hp_lovecraft is offline
rear brakes on a 69 cj5 challieboy27 Jeep CJ Forum 2 02-19-2011 09:34 PM
No rear brakes on a 78 CJ7 SpencerC Jeep CJ Forum 18 10-03-2008 01:24 PM
Drum Brakes...How I Hate Thee Scott_MH Jeep CJ Forum 4 03-30-2008 08:11 PM
I hate to even ask.......brakes :( CJ Fanatic Jeep CJ Forum 7 06-27-2006 06:24 PM
rear brakes yttims Jeep CJ Forum 4 04-28-2005 09:25 AM
