#1 | |
Rear brakes
I put in a new set of rear brakes a few weeks back. The right side works fine.
The left side works fine for about 10 miles. At that point they start squealing. At first just a little, then a lot. I can pull the hub off, inspect everything, put the hub back on, readjust the brakes and the pattern starts all over. I compared left to right and everything is identical. Are both adjusters (right and left) the same? Could one have left hand threads so the brakes get out of adjustment? I put new ones on but did not compare them. The brake pads on both shoes show a 45 degree wear at the etreme upper edge of the pads. Any ideas?
Weber 32/36 DGEV, 4" Suspension Lift , 1 " body lift 8000 lb Winch, ViAir Onboard Air TeamRush ignition upgrade with MSD 6a CDI Dual Batteries KC Daylighters Cold Air Intake Lock-Right Lockers Yukon 1 piece axles Custom Bumper& Swing Out Tire Carrier Mile Marker Hubs Chevy Blower Upgrade 1500 lb airbag suspension Floor mounted gun rack (2 guns) |
#2 |
Is the drum to hot to touch when you finally stop? I replaced both of my star wheels and they sold me a right and a left. Did you turn the drums to brake the glaze? They shouldn't be wearing they way they are so soon.
1979 CJ5 360 V8 w/Holley 470 Truck Avenger, HEI Ignition, Livewires w/E3 Sparkplugs, Hedman Hedders, Flowmasters, DANA 30 w/Auzzie Locker, AMC 20 limited slip "N" 3:54's, Tuff Country 2.5" lift, Rancho RS5118, Rubicon Express Quick Disconnects, Currie 1/2" lift Heavy Duty Greasable Shackles, DANA 20, T150, Mile Marker PE8000 w/MiFi Controll Box, Bestop Super Top, Warn 6 bolt Premiums, 31x10.50x15 |
#3 |
GROUND POUNDER
The adjusters are left/right specific... left hand thread and right hand thread.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#4 |
I bet they sold me two right sides. Any idea which way you would have to turn the star wheel on the left side to expand the brakes?
#5 |
Ok back to the drawing board. The adjuster is marked L and has the opposite thread as the one marked r.
The drum is not hot to the touch as asked by flashawk.
#6 |
I was just thinking about the way you're brakes are worn, that's got to have something to do with you're problem. What size drums do you have? If I remember right, they should be 10 inches and if you have the wrong size shoes (to small), that could cause them the ware like you described.
#7 |
The adjusters are not the same. Left is different from right - opposite threads.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc. |
#8 |
Right hand thread goes on left rear, left hand thread goes on right rear.
#9 |
Anyone know whether the stock 1980 cj 7 came with 1 7/8 rear brake shoes or 2"?
#10 | |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Oh, when adjusters are on the wrong side, the brakes loosen off, not get too tight.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#11 | |
#12 | |
Off Road Forever
If you now have new and the drum doesn't get hot or have any new notches worn in it with metal shavings laying around, then you should be looking for other causes of the wheel noise. What shape is the wheel bearing in? Is the backing plate bent or showing fresh wear marks any place?
#13 | |
They should not be identical. They should be mirror opposites. If they are identical they would adjust tighter every time you hit the brakes. Which sounds like what is happening.
80 CJ-5, 74 CJ-6, 56 CJ-5 |
#14 | |
No wear marks on the backing plate. Keep the ideas coming. This has to be something simple I am over looking. A synopsis: New wheel bearings, new inner and outer seals, new flange on the axle, new drums, new shoes all new hardware. Right side works fine, left squeals after about ten miles. Thanks for all the help///
#15 |
What if you're star wheel is in back wards or seized up? That might cause the brake shoes the ware at the bottom opposite the wheel cylinder while driving. Once the excess is worn (after 10 miles) the squealing stops. I still think it might have something to do with you're star wheel (broken, buggered threads). Who knows? You asked to keep the ideas coming, I'm just pondering over here.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
