rear axle re-installation for dana 44
| Spartan Lockers FREE SHIPPING Excellent Prices | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ |
#1 | |
Just want to make sure this is done right. Tomorrow I should hopefully have the right new bearing and seal and get them pressed on the axle. The salesman at napa tried to tell me that there was only one bearing for my year jeep, which i new wasnt true, so I figured there was a 50/50 chance getting the wrong one, which was what happened. Then I should tap the race into the axle housing, put a light coat of grease around outside of seal, install axle and tighten bolts on the retainer plate. When I removed it today, I had to scrape a light coat of sealant where the retainer plate was, not sure as to the reason it would be there, but is that something I should do, is put some sealant on the retainer plate?
#2 |
I heart bacon and pie
The bearing should be "set 10". I have read articles saying to put some silicone on the outside of the axle seal. I've put axles in with and without silicone and I have not had leaks either way with new seals. The only leaking axle seals I had were with seals having over 175K miles on them.
#3 |
So just tell the parts guy I need a "set 10" bearing. Thank You!!! that should be easy enough
#4 |
One last question. It seems that the bearing would get lubed from the gear oil in the axle housing, so do I still need to pack the bearing?
#5 |
CJ OWNER FOR LIFE
yes, If it has no seal on the diff side of the bearing, the lube will be it. I would install it wet or jack up each side to lube it after its all together. I always had to use silicone on the retaining plate or it would leak at the plate seam.
Ed 1975 CJ-6 304 T15 Dana20 30/44 3.73 1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade 1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31 1986 TJ-7 Trail Jeep project in the works 2003 Inca Gold TJ Rubicon |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
