Rear Axle end play - JeepForum.com
post #1 of 12 Old 09-24-2003, 09:13 PM Thread Starter
GwenStrough
Rear Axle end play
While installing new oil seals on the right rear axle of my 1981 CJ7, I noticed a small amount of end play. After taking the axle out, I checked the left rear axle and there is at least a quarter-inch end play. Is there end play on the driver's side because the right side axle is out? How much end play should there be, once all is back together? Is that much end play hard on oil seals? What is actually moving on the axle to cause the end play?
GwenStrough is offline
post #2 of 12 Old 09-24-2003, 09:24 PM
only in a jeep cj
On the Model 20 axle, the bearings are positioned where the race is on the outer side of the bearing set. This makes the axles "push" inward while under a rotating load. Thats why there is a center block over the main shaft in the diff casing. There is then a shim pack on the drivers side that give you the correct endplay.
Sooooo, with one of your axles removed, yes there is a bunch of movement there.
(one piece axles have the bearings like the dana set up and the above does not apply)
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 12 Old 09-25-2003, 05:53 AM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I am slightly confused by your statement.
Do you need to reinstall the shims with the 1 piece set up or no? i just did the 1 piece install and I didn't seem to need the shims...
I could be wrong though.
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #4 of 12 Old 09-25-2003, 11:23 AM
only in a jeep cj
cb
The info was for the stock 2 piece set up where you need shims on one side to get the correct endplay in both axles (through the diff block)
No shims on the one piece set up. Instead there are spacers used in the tube ends that make the bearing stick out .006 and the backing plate holds it tight. Some even say to remove the diff block in case the aftermarket axles have longer splines and you have trouble installing the second axle to the correct specs.
Ed
1975 CJ-6 1983 CJ-8
post #5 of 12 Old 01-24-2014, 01:32 PM
guscj7
my 1980cj7 amc 20 rear a lot of play almost 1/4 turn on drive shaft what do u think
guscj7 is offline
post #6 of 12 Old 01-24-2014, 03:06 PM
LumpyGrits
That's not axle end-play.
You have issues with either with pinion slop or carrier bearings.
Either way-I would NOT drive it till fixed!
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #7 of 12 Old 01-24-2014, 03:07 PM
LumpyGrits
End play is only measured when BOTH axles are installed.
LG
post #8 of 12 Old 01-24-2014, 06:26 PM
tjeep1
1978 CJ7
certifiable i had to use a few of the shims when i put my 1 piece axles in but it depends on your clearence ,mine was binding a little so i shimmed it and it is fine
tjeep1 is offline
post #9 of 12 Old 01-24-2014, 08:59 PM
certifiablejeep
Bicentennial Nickel
1976 CJ5
ummmmm, WOW, holy old thread... I posted that question 11 years ago...
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #10 of 12 Old 01-25-2014, 02:17 PM
guscj7
i pulled off cover did not no oil was silver pinion gear hitting the carrier still has some beef is this going to be big dollars or should i look for used rear
guscj7 is offline
post #11 of 12 Old 01-25-2014, 02:28 PM
skizriz
1978 CJ7
Yes.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #12 of 12 Old 01-26-2014, 10:03 AM
LumpyGrits
Huh??
Have a pro look it over. You may have collapsed the 'crush-sleeve' on the pinion is all.
STOP DRIVING IT TILL FIXED!
ALSO, buy a real FSM and learn how things work.
LG
How much play in rear differential? NevadaM Jeep CJ Forum 1 10-27-2008 09:11 AM
Narrowtrack rear axle with 2" spacers match up with a widetrack front axle? Blthomas Jeep CJ Forum 1 05-11-2007 08:25 PM
Should there be end play on Dana 30 axle shafts? fromme Jeep CJ Forum 9 01-31-2006 07:03 AM
Axle Play Question? Shop is trying to bull-=-=-=-=-=-=-=-= me... Hale Jeep CJ Forum 8 03-28-2004 03:08 AM
Getting rid of end play on amc 20 axle (HELP!!) Bryan L. Jeep CJ Forum 4 08-11-2002 02:24 PM
