Rear 20 Disc Upgrade - Page 5 - JeepForum.com
post #61 of 67 Old 01-16-2010, 12:02 AM
jfwireless
1976 CJ7
Originally Posted by Fourtrail View Post
Not sure if it is an optical illusion, but in the middle pic above, the caliper mount doesn't look to be parallel to the rotor. This would cause the binding issue if the caliper a not true to the rotor.
I agree , it just doesn't look right. My rear disk brakes on my AMC20 do not drag at all
Jim
jfwireless is offline
post #62 of 67 Old 01-16-2010, 07:15 AM
CJman77
1977 CJ7
Jim
Well like I said before thats the cause of the angle the pic is taken I have used levels etc to assure myself the bracket is straight
CJman77 is offline
post #63 of 67 Old 04-01-2010, 07:44 AM
locked-up-XJ
Do you have to use 1 piece axles when doing this upgrade? I would like to do this upgrade but i am waiting to break my 2 piece axles before i upgrade to the 1 piecers.
1999 TJ Custom 3 Link, 2.5" FOA Coilovers, 4.88 gears, Trussed D30, Locrite lockers, 35" MTR's
85' CJ7 Project "Bentsome"
In Progress
locked-up-XJ is offline
post #64 of 67 Old 04-01-2010, 07:47 AM
CJman77
1977 CJ7
I dont see why it wouldn't work. You will mount the bracket in the same place.
CJman77 is offline
post #65 of 67 Old 05-17-2010, 11:24 AM
Stan99
1978 CJ7
Just a quik question. I finally picked up some rear calipers off of a 96 maxima and the only thing I dont like is how long the rubber hose is. The hose off of the 300z looks like it is atleast half of the size in length. Does anybody know if they are compatible?
I have brand new brake lines on my axle and I dont want to have to cut them down to make it work.
1978 Jeep Cj7 Soa, Shackle Reversle, 36x13.5x15 Irocks, 4.5 Stroker MPI, Dana 300 twin Sticked, 4.88's
Stan99 is offline
post #66 of 67 Old 02-20-2011, 06:45 PM
DaracF
1977 CJ7
Hey Jim, is your braket for your E brake just mounted to the spring plate? Would you happen to have any other pics of that?
And did you have to mod the 300z caliper mounting bracket at all? I made some of the brackets that mount the caliper at the top of the rotor, but I like the idea of retaining the e brake like you did and gravity bleeding the brakes. I'm going to pick up some calipers this weekend and was wondering if I should snag those brackets too.
DaracF is offline
post #67 of 67 Old 01-29-2013, 07:31 PM
Thbugman
1978 CJ7
Just marking this thread to use as a guide.
Thbugman is offline
CJ rear AMC 20 disc brakes coxhaus Jeep CJ Forum 23 04-03-2011 12:28 AM
rear disc brakes Anyone???? Bill Hall Jeep CJ Forum 25 09-04-2008 09:11 AM
Rear disc brakes CJoe Jeep CJ Forum 3 04-25-2007 01:18 PM
Rear Disc Brakes Workethic Jeep CJ Forum 1 01-01-2006 03:41 PM
Disc Brakes for Scout 44 Rear?? TonysCJs Jeep CJ Forum 6 08-10-2005 12:39 AM
