Rear 20 Disc Upgrade - Page 4 - JeepForum.com
post #46 of 67 Old 12-16-2009, 12:45 AM
wrongway92407
wrongway92407's Avatar
When I upgraded my 76 CJ7 rear AMC 20 to disk brakes I pulled the stub axles out of the donor 300zx and cut the caliper brackets off and used them on the AMC 20. Fit very nicely and I used three bolts to bolt up the the axle flange. Had to use a few spacers to center the caliper onto the Suzuki Samari rotor. I found it cheaper to buy the rotors new than to buy used ones at the junkyard. They were cheap. The rear CJ emergency brake cables also worked, as I used the mounting block on the end of my emergency brake cables to mount the cables and attach them to the caliper. Later model CJ's did not have this mounting plate on the end of the emergency cable.
So you have to pull the stub axle out, to get the brkt, you can't unbolt it from the swing arm? I didn't that close of attention but I thought they unbolted ,like the Maxima.!
wrongway92407 is offline
post #47 of 67 Old 12-16-2009, 06:33 AM
jfwireless
1976 CJ7
No, they were welded onto the stub axles.
Jim
jfwireless is offline
post #48 of 67 Old 12-16-2009, 09:09 AM
Totallymetal
Originally Posted by CJman77 View Post
Hmm 1 ton axles, too bad your not closer I have a Dana 60 front and 14 bolt rear I need to unload!
I am a long ways from doing that upgrade. I have to break my current set up before I can justify the time and expense. I also need a bigger shop, so I can take my time. The Jeep is sharing the garage with 2 other cars (wife and mother in law).
2007 JK Rubicon
5.5 Rock Krawler X-factor lift w/37 x 12.5 x 17 BFG KM2s, 5.13 Superior gears
Warn Powerplant HD
Totallymetal is offline
post #49 of 67 Old 12-17-2009, 10:26 PM
wrongway92407
Jim
I spent about 5 hours in the pic a part, found 1 94 Maxima, and about 1/2 a dozen 300 z cars. The thing I noticed was the way the parking brake hooked up. The Maxima's use a hook for the cable that has a elongated slot to hook into. The z car's had a swedged end on the cable like the jeep cable, but the ones I looked had a clevis pin that the cable went through, Jim is that what you have?
post #50 of 67 Old 12-18-2009, 07:55 AM
jfwireless
1976 CJ7
Jim
As soon as it stops raining here I will go out to the shop and get a pic of the caliper I am using.
Jim
post #51 of 67 Old 12-18-2009, 11:06 AM
jfwireless
1976 CJ7
Here are some pictures of the ZX caliper I used on my 1976 CJ-7 rear AMC 20 disk upgrade project. The first picture is of the caliper itself, at the bottom of the picture you can see the emergency brake spring and clip to hold the emergency brake cable end.
The second picture shows the angle bracket I made to support the emergency brake cable support bracket that is part of the CJ 76 emergency brake cable. This bracket used to bolt up to the back of the brake drum.
The third picture shows the CJ emergency brake cable attached to the ZX caliper.
Hopefully this helps
Jim
post #52 of 67 Old 12-18-2009, 08:55 PM
wrongway92407
Jim, thanks for the pic's, the ones that I've been finding out here are a little different for the parking brake. The parking brake cable where it hooks to the caliper as in the #3 pic on the ones I have found that piece has a split loop with a clevis pin the cable goes through the split loop and is held tn place by the clevis pin. This is hard to explain so tomorrow I will take a pic with my phone. this is an 87 but the catalog says they are the same. In pic #1 what is the flat bar with the slot opposite the brake hose for? Thanks Dave
post #53 of 67 Old 12-19-2009, 12:13 AM
jfwireless
1976 CJ7
You can also see it in picture #3, it is a guide for the emergency brake cable.
Notice I installed the caliper in the same position as in the 300zx on the back side not on top for two reasons, so the bleeder valve would be on top, and so the OEM CJ emergency brake cable would fit. Many install the caliper on top, but I installed it on the back side as originally installed on the 300zx. That is why I removed the original caliper mounting brackets from the 300zx stub axles. The ones everybody was selling ended up mounting the cailiper on top, not on the back side. After installing the calipers I bleed the brakes with a simple gravity feed, worked just fine.
Jim
post #54 of 67 Old 12-19-2009, 12:36 AM
wrongway92407
Ok gotcha it looks different in the 2 pic'c
Thanks Dave
post #55 of 67 Old 01-06-2010, 04:41 PM
CJman77
1977 CJ7
Hey you guys that have done this upgrade.
Have you had any pad dragging issues? I am having slight issues I can turn the rotor by hand but I hear the pad on the rotor lightly in certain areas. Should I worry about this? Or should I just let it wear in a bit?
I have tried everything I can think of to try to widen the caliper "grip"
Any suggestions?
CJman77 is offline
post #56 of 67 Old 01-06-2010, 06:58 PM
Totallymetal
They will always touch, but should not make it difficult to turn the rotor. Compare with your front discs they should feel and sound the same.
2007 JK Rubicon
Warn Powerplant HD
post #57 of 67 Old 01-06-2010, 07:31 PM
CJman77
1977 CJ7
Yeah they are touching a little...I found that my rotor was rubbing a tiny bit on the maxima cal bracket. So I went at it with a file and no more rubby. The axle turns no problem, but its not like super loose which I am assuming is a good thing. ALL the guts in the diff are brand new except the carrier. So there is no wear and its freshly built so I am assuming this is normal. Also its not full of fluid yet just sprayed down with some WD40 to stop rust.
Some pics!
CJman77 is offline
post #58 of 67 Old 01-15-2010, 08:15 PM
CJman77
1977 CJ7
hmmm well I am having major dragging issues. Kinda starting to wish I would kept the drums....THis is a pain NTM I think the brand new rotors are no where close to true
CJman77 is offline
post #59 of 67 Old 01-15-2010, 11:03 PM
Fourtrail
1974 CJ6
Not sure if it is an optical illusion, but in the middle pic above, the caliper mount doesn't look to be parallel to the rotor. This would cause the binding issue if the caliper a not true to the rotor.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #60 of 67 Old 01-15-2010, 11:15 PM
CJman77
1977 CJ7
Yeah I know what your saying.....Its a product I believe of the angle I took the pic at. Cause I made sure it was straight.
CJman77 is offline
CJ rear AMC 20 disc brakes coxhaus Jeep CJ Forum 23 04-03-2011 01:28 AM
rear disc brakes Anyone???? Bill Hall Jeep CJ Forum 25 09-04-2008 10:11 AM
Rear disc brakes CJoe Jeep CJ Forum 3 04-25-2007 02:18 PM
Rear Disc Brakes Workethic Jeep CJ Forum 1 01-01-2006 04:41 PM
Disc Brakes for Scout 44 Rear?? TonysCJs Jeep CJ Forum 6 08-10-2005 01:39 AM
