Rear 20 Disc Upgrade - Page 3 - JeepForum.com
post #31 of 67 Old 12-10-2009, 11:31 PM
Totallymetal
This is the one I started out with. Printed it out, marked it out on a piece of metal and had a friend cut the shape with a plasma cutter. I did mark the holes mocked up in place with clamps. The piece on the left is for mounting the emergency brake, I haven't got around to doing that yet.
2007 JK Rubicon
5.5 Rock Krawler X-factor lift w/37 x 12.5 x 17 BFG KM2s, 5.13 Superior gears
Warn Powerplant HD
Totallymetal is offline
post #32 of 67 Old 12-11-2009, 03:59 AM
wrongway92407
wrongway92407's Avatar
Thanks, I can transfer this and with a little bluing cut that out on the mill. I was shopping for parts and found a 300Z but didn't have all the tools I needed but will get the stuff this weekend. Thanks again!
wrongway92407 is offline
post #33 of 67 Old 12-14-2009, 06:49 PM
CJman77
1977 CJ7
Hey totallymetal what did you do about rear brake lines? I am using the 96 maxima calipers and I am wondering if the stock maxima line will work? Do I need to buy stock lines and have the ends changed? thanks
What did you do?
CJman77 is offline
post #34 of 67 Old 12-14-2009, 09:01 PM
Totallymetal
The stock maxima rubber line (female) went together perfectly with the CJ (male) steel line. I had to bend the steel line around to make it work.
2007 JK Rubicon
Warn Powerplant HD
post #35 of 67 Old 12-14-2009, 09:25 PM
CJman77
1977 CJ7
TM good to hear I will buy some new stock maxima brake lines. Out of curiosity how were you going to do your hydroboost?
CJman77 is offline
post #36 of 67 Old 12-14-2009, 10:42 PM
Totallymetal
I have the hydroboost and MC from a 1 ton Chevy. I am going to fit it, and see how it performs. I will be replacing all of the 30 yr old brake lines at the same time.
2007 JK Rubicon
Warn Powerplant HD
post #37 of 67 Old 12-15-2009, 01:30 AM
wrongway92407
I was thinking about a hydroboost from an Astro van, There are plenty of those in the pic and pull not sure what years they are. It finally stopped raining here, so I can get out and grab the parts for my rear disc brakes. Is there any diff in the calipers between the Maxima or the Z car, or is the diff in the mtg bkt. luckily I have spare mdl 20 that I can mock up everything.
post #38 of 67 Old 12-15-2009, 07:59 AM
jfwireless
1976 CJ7
Originally Posted by ACAD_Cowboy View Post
Drafters do it in excruciating detail. I found a PDF in one of the link showing the caliper mounting plate details but found it would be a nightmare for a layman to try to layout and cut. So for anyone who is interested, I can hook you up with both a print copy and a DXF file for use with CNC Laser, CNC Plasma or CNC Router. I Could probably also supply a plywood buck for those who are in the building phase and need templates.
When I upgraded my 76 CJ7 rear AMC 20 to disk brakes I pulled the stub axles out of the donor 300zx and cut the caliper brackets off and used them on the AMC 20. Fit very nicely and I used three bolts to bolt up the the axle flange. Had to use a few spacers to center the caliper onto the Suzuki Samari rotor. I found it cheaper to buy the rotors new than to buy used ones at the junkyard. They were cheap. The rear CJ emergency brake cables also worked, as I used the mounting block on the end of my emergency brake cables to mount the cables and attach them to the caliper. Later model CJ's did not have this mounting plate on the end of the emergency cable.
I should have made a template for others at the time of the caliper mounting brackets I cut off the 300zx stub axles, that would have been a good idea. I did trace them onto a cardboard box in the shop. Maybe I can make something out of that tracing if anybody is interested.
Jim
jfwireless is offline
post #39 of 67 Old 12-15-2009, 08:33 AM
Totallymetal
Lots of people using the Astro van. Looks like a good choice.
I don't know, they very well could be the same calipers.
2007 JK Rubicon
Warn Powerplant HD
post #40 of 67 Old 12-15-2009, 08:35 AM
Totallymetal
This is a good template in PDF.
CJ-adapter
2007 JK Rubicon
Warn Powerplant HD
post #41 of 67 Old 12-15-2009, 08:38 AM
CJman77
1977 CJ7
How do you adapt the astro van hydroboost to work on the jeep firewall?
CJman77 is offline
post #42 of 67 Old 12-15-2009, 08:43 AM
Totallymetal
I haven't done it. I would assume there are probably modifications to the mounting bracket and push rod coming from the brake pedal.
Keep in mind these are modifications to your brake system. Very dangerous if not done correctly.
2007 JK Rubicon
Warn Powerplant HD
post #43 of 67 Old 12-15-2009, 05:51 PM
CJman77
1977 CJ7
Yeah....Why a 1 ton trucks hydroboost on a little Jeep cj? Wouldnt a vaccum be enough?
CJman77 is offline
post #44 of 67 Old 12-15-2009, 09:04 PM
Totallymetal
Vacuum would probably be plenty, but I figured with 35s and maybe larger in the future (after 1 ton axles), why not. I got the set up for next to nothng. If it's too much, I will sell it and go vacuum.
2007 JK Rubicon
Warn Powerplant HD
post #45 of 67 Old 12-15-2009, 09:20 PM
CJman77
1977 CJ7
Yeah I hear ya.. I am thinking I may go vaccum I had my eye on the one that morris 4x4 sells.
Power Brake Unit w/ 8" Dual Diaphragm*MBM-PBUJ7486 by the Jeep Specialists | Morris 4x4 Center
Hmm 1 ton axles, too bad your not closer I have a Dana 60 front and 14 bolt rear I need to unload!
CJman77 is offline
CJ rear AMC 20 disc brakes coxhaus Jeep CJ Forum 23 04-03-2011 01:28 AM
rear disc brakes Anyone???? Bill Hall Jeep CJ Forum 25 09-04-2008 10:11 AM
Rear disc brakes CJoe Jeep CJ Forum 3 04-25-2007 02:18 PM
Rear Disc Brakes Workethic Jeep CJ Forum 1 01-01-2006 04:41 PM
Disc Brakes for Scout 44 Rear?? TonysCJs Jeep CJ Forum 6 08-10-2005 01:39 AM
