Really Low Idle and Running Cold - JeepForum.com
post #1 of 3 Old 08-15-2013, 08:24 PM Thread Starter
jerm1978
I have a CJ7 with a 304. Nothing major; pretty much stock. Recently though its having a hard time idling (any gear including park).
It's idling very low. It does this when I first crank up. Then once I let it run it gets a little better, but then once driving around for twenty minutes it starts going bad again and sitting at a red light it gets so low I have to give it gas to keep it from dying. I've also noticed that its running cold. My gauge doesn't show actual temps, but its running at half of what it has always run at and I've had the Jeep for 12 years (even in 100 degree weather).
When you give it gas and your running at speed it seems fine. Over course because its having such a hard time to idle and keep up its RPMs, its a hard time charging.
Any ideas what this could be?
Thermostat? Water Pump? Timing?
jerm1978 is offline
post #2 of 3 Old 08-15-2013, 08:29 PM
Texian
1978 CJ7
I think your thermostat is stuck open. I imagine your gas mileage has taken a major hit too.
Kind of surprised that the fast idle on your choke hasn't engaged.
Easy and cheap fix.
Texian is offline
post #3 of 3 Old 08-15-2013, 08:59 PM Thread Starter
jerm1978
Don't know about the gas mileage because it idles so I don't dare to drive it very far from the house.
jerm1978 is offline
