A real bad night - JeepForum.com
post #1 of 5 Old 10-02-2005, 10:31 PM Thread Starter
gigihurt
gigihurt's Avatar
A real bad night
Last night me and some of the locals decided to go riding in a local mud hole after the roy jones fight HA HA HA. I darted home right after the fight to grab my waders and boots from my shop and the jeep stalled in the back yard. Went to start the dang thing back up and she wouldnt even turn over. I tried the big charger tapping the starter and jumping the cylinoid only to find the motor was locked up. Talk about pain in the arse. I new I should have had a V8
83 cj7 all stock except lift and tires and all the drive train.
gigihurt is offline
post #2 of 5 Old 10-03-2005, 08:03 AM
Rockram1
Hydro locked! Damn! hate it when that happens! Pull all the sparkplugs and try to turn the engine over. Hopefully you can push the water out.
And no internal damage was done. Good luck. Hey now's the prefect time to install that v8 you've been eye balling.
86 CJ7, 258, t18, D300, D44's 4.56's, Detroit front, Warn shafts and CTM joints, spool rear, SOA, SRS, waggy springs, 6 point cage, Warn winch, 38" Tsl, Allied beadlocks.
Rockram1 is offline
post #3 of 5 Old 10-03-2005, 08:35 AM Thread Starter
gigihurt
gigihurt's Avatar
Originally Posted by Rockram1
Hydro locked! .
I already pulled the plugs just in case that was the problem. I do beleive something broke or it spun a bearing and seized up. The bad part is it didnt even make any odd noises.
gigihurt is offline
post #4 of 5 Old 10-04-2005, 04:42 PM
chevy power
Well on the up side at least it went home to die. Sorry about your luck, Does the oil have any water in it? Seems odd though that it just up and died without any warning. Did it overheat or anything unusual? Anyone really mad at you?
67 cj5 Chevy v8-t18 S.O.A.
chevy power is offline
post #5 of 5 Old 10-04-2005, 05:06 PM
timmymorg
(Did it overheat or anything unusual? Anyone really mad at you?) LOL. The ol "sugar in the gastank trick" is a possibility.
See if you can put a wrench on the bolt on the front of the crank bolt on the front of the block (plugs out of course) and spin it free by hand. If youve got a 258 and it gets loose, you will probably need to think about tearing it down in the next 100K miles or so (lol).
Seriously, if you get it free and can get the water out, change the oil, you may be able to get er fired up again. But you will still need to tear it down to check for damage pretty soon.
T
timmymorg is offline
Got her home last night! danheit Jeep CJ Forum 41 02-03-2012 05:23 AM
What Happened To The Forum Over Night?! JeepHammer Jeep CJ Forum 10 10-09-2009 09:09 AM
Need some real help with the one trombl76 Jeep CJ Forum 2 10-08-2007 03:14 PM
Is this for real?? egabriella Jeep CJ Forum 6 01-24-2007 10:54 AM
Constant problems... getting real fed up real fast! Mastermind Jeep CJ Forum 3 07-13-2003 10:34 AM
