A Real Answer To The Dreaded Cj Lean, Can It Be Fixed - Page 4 - JeepForum.com
post #46 of 56 Old 12-26-2013, 04:11 PM
hasselback
Originally Posted by Bubba Ray
I checked his site and did not see it. Does anyone have a drawing or pics to go by? Would you need new u bolts?
I'll have pics as soon as I get too it! As for the u bolts, you shouldn't, unless they were cut off shorter. I still have at least an inch of thread or more on mine.
1984 CJ7 I6 258 Bone stock
"Screw the brakes, just make the horn louder!"
My build thread
hasselback is offline
post #47 of 56 Old 12-27-2013, 04:25 PM
hasselback
Ok, so here's my fix to the lean. As you can see, I was leaning a little more than an inch, so I turned down the u bolt nuts until I had a gap between the perch and spring pack that was enough to level out the jeep. Then I took two 4 inch pieces of 1 inch square tube, welded them together, and welded some ends on. This made a block just the right size to fill the gap. Next, I drilled a hole in the center to go over the centering pin on the spring pack, and I'll weld a half inch nut in the center on the other side to go in the hole in the perch. All should be well now! I had all the materials, so total cost was zero, but the square tube was $12 at tractor supply.
My build thread
post #48 of 56 Old 12-27-2013, 04:42 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The hollow tubing would make me nervous.
I probably would have welded solid steel directly to the spring perch.
But, I'm glad your CJ no longer looks crippled. I'd keep a watchful eye on that block.
Matt
Matt1981CJ7 is offline
post #49 of 56 Old 12-27-2013, 04:53 PM
hasselback
Matt
The tubing is a little on the thin side, but it's essentially doubled up in the center, plus I made the ends out of 1/4 inch plate. So it shouldn't collapse. Won't get to put the block in until Sunday now, but where I have it sitting, she's nice and level all the way around now!
My build thread
post #50 of 56 Old 12-29-2013, 05:33 PM
hasselback
Got my shim block finished up and installed today. Going to have to get longer u bolts though. I was able to get the nuts on these ones, but there was only about 3/8 of an inch of thread sticking though the plate. It's holding for now, and it's nice and level, but longer u bolts will definitely be installed before I drive it!
My build thread
post #51 of 56 Old 01-15-2014, 01:45 PM
1978CJ7Beast
1978 CJ7
Shim block I ordered installed on rear passenger side. Definitely made a difference. My lean was significant - and I'm about level now.
"What will all that chatter and hearsay count (will you even be able to remember it?) when the anaesthetic fog which we call "nature" or "the real world" fades away and the Presence in which you have always stood becomes palpable, immediate, and unavoidable? - C.S. Lewis"
1978CJ7Beast is offline
post #52 of 56 Old 01-16-2014, 11:34 AM
Renegade82
1982 CJ7
This may have been on this thread, but I seen it somewhere. What was AMC's fix for this common problem?
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #53 of 56 Old 01-16-2014, 11:38 AM
waterdowg
Did you buy the kit from Eric? Do you have pictures of the shims before you installed them?
waterdowg is offline
post #54 of 56 Old 01-16-2014, 12:09 PM
Matt1981CJ7
1981 CJ7
A shim at the right rear spring perch, just like these guys are doing.
Matt
post #55 of 56 Old 01-16-2014, 12:19 PM
1978CJ7Beast
1978 CJ7
Yep. Bought from Eric. "Kit " includes shim and instructions. Here's the shim.
post #56 of 56 Old 01-16-2014, 12:21 PM
1978CJ7Beast
1978 CJ7
Sorry. Here 's the pic.
Dreaded Leaky Heater Core chadcarter Jeep CJ Forum 10 05-23-2009 06:46 PM
Jeep Lean! Etchandy Jeep CJ Forum 12 12-06-2008 12:05 AM
dreaded door hinge bolts CJ7 Vette Jeep CJ Forum 5 08-05-2007 08:25 PM
The infamous CJ Lean and how to fix it... real world question '79 CJ-7 Levi Jeep CJ Forum 24 09-13-2005 11:02 AM
Constant problems... getting real fed up real fast! Mastermind Jeep CJ Forum 3 07-13-2003 11:34 AM
