A Real Answer To The Dreaded Cj Lean, Can It Be Fixed - JeepForum.com
post #1 of 56 Old 01-30-2009, 10:50 AM Thread Starter
baystrucksalvag
1976 CJ5
ok i have read post's 'till i am dizzy, is there any REAL explanation for it, and any real fix?
hey yall' watch this!!!!!
baystrucksalvag is offline
post #2 of 56 Old 01-30-2009, 10:53 AM
NJblackdeath4x4
buy an xj
sry i dunno
NJblackdeath4x4 is offline
post #3 of 56 Old 01-30-2009, 11:05 AM Thread Starter
baystrucksalvag
1976 CJ5
an xj if i wanted a chrysler i'd buy an new yorker
post #4 of 56 Old 01-30-2009, 11:10 AM
texasdave
texasdave's Avatar
1980 CJ7
Lose weight? Don't let fat chicks drive you rig? Add an extra leaf or change the springs with more leaves to make it more ridgid. You may also have body mount issues that the bushings have deterioated and replace with poly mounts.
texasdave is offline
post #5 of 56 Old 01-30-2009, 11:12 AM
CrazyHorse6
1979 CJ7
When I first bought my jeep the PO had a smaller tire on the drivers front, so that's what I thought was causing the lean.....but nope, after a resto and new tires it seems to be in the frame like other posters have said. Whether due to frames being stacked and tightened down on rail cars to whatever the other suggested reasons were, my drivers front is about 1 1/2" lower than the rest of the jeep. I used spacers above the body mounts to bring it up a little bit and make it less obvious, but I'd love to hear a more effective solution. Jack up the outside seat mounts a little so at least you sit straight up and down?
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #6 of 56 Old 01-30-2009, 11:27 AM
crusty75
1975 CJ5
For years, dealers installed shims under the HIGH side spring to fix this when a customer complained. My wife bought our jeep new in 75, and it after a while took it to the dealer with the problem.
Last summer, I replaced the worn out springs with new stock height ones, and found a 1/2" steel shim under the driver's rear spring. When I replaced with new springs, I reused the shim, just to see what would happen. I was fully prepared to remove the shim if necessary because of the new springs.
Turns out I saved myself a little work by reusing the shim. The jeep sits to within 1/8" of level with the shim installed. Good enough for me.
This tells me that whatever the cause of the problem, it is not in the spring packs, or the shim would have been unneeded with brand new springs.
So as far as I'm concerned, I don't know the cause, but the old dealer installed solution has negated the problem for 34 years now.
But what do I know? I'm old.
crusty75 is offline
post #7 of 56 Old 01-30-2009, 12:21 PM Thread Starter
baystrucksalvag
1976 CJ5
i have heard that shimming the HIGH side would help so that dealer fix sounds reasonable
post #8 of 56 Old 01-30-2009, 12:37 PM
molsenice
1964 CJ5
sorry - I couldn't see past yer avitar
molsenice is offline
post #9 of 56 Old 01-30-2009, 12:47 PM
CrazyHorse6
1979 CJ7
So shimming the HIGH side allows more weight to be exerted on that side, thus bringing it down and the once low side up? I'm confused.
post #10 of 56 Old 01-30-2009, 01:14 PM
1984CJ
1984CJ's Avatar
No. Shimming the spring on the high side lowers the high side to help level the frame.
It does this by moving the spring plate away(down) from the axle tube.
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline
post #11 of 56 Old 01-30-2009, 01:53 PM
80cj
80cj's Avatar
1980 CJ5
Wish he'd post an enlargment of it (her).
Actually, the Jeep lean is very common. Probably more Jeeps leaning than level ones. How bad is she leaning? Could it be because she's a might top heavy?
80cj is offline
post #12 of 56 Old 01-30-2009, 04:21 PM
CrazyHorse6
1979 CJ7
AHHHHH. I got it now. I was picturing a "spring over" setup in my head. Axle stays the same height, spring plate goes down, therefore frame goes down. I'm an idiot. Thanks
post #13 of 56 Old 01-30-2009, 04:23 PM
Gunga
1978 CJ7
I had one of my front springs re-arched to even mine out. $50.00 deal.
'78 CJ-7, 401 w/ headers, T-18, 35" muds, 4" lift, MSD ignition box, locked diffs.
Gunga is offline
post #14 of 56 Old 01-30-2009, 05:39 PM
80cj
80cj's Avatar
1980 CJ5
I had that done to mine and in a few months it was back to leaning again. Since then, I don't let it bother me. Leans toward the driver's side about 3/4".
80cj is offline
post #15 of 56 Old 01-30-2009, 07:06 PM
Tractor Boy
1977 CJ5
I had a Rubicon Express 2.5" lift on mine and that cured the gangsta lean on mine.
Tractor Boy is offline
Dreaded Leaky Heater Core chadcarter Jeep CJ Forum 10 05-23-2009 05:46 PM
Jeep Lean! Etchandy Jeep CJ Forum 12 12-05-2008 11:05 PM
dreaded door hinge bolts CJ7 Vette Jeep CJ Forum 5 08-05-2007 07:25 PM
The infamous CJ Lean and how to fix it... real world question '79 CJ-7 Levi Jeep CJ Forum 24 09-13-2005 10:02 AM
Constant problems... getting real fed up real fast! Mastermind Jeep CJ Forum 3 07-13-2003 10:34 AM
