re use dizy on new engine? - JeepForum.com
post #1 of 5 Old 07-04-2013, 12:10 PM Thread Starter
spottedfrog
1979 CJ5
Is it ok to re use my old dizzy on a new engine if I replace the cam gear and the pickup coil?
spottedfrog is offline
post #2 of 5 Old 07-04-2013, 12:11 PM
agear
I reused my distributor when I installed a reman'd 258.........
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #3 of 5 Old 07-04-2013, 12:14 PM
LumpyGrits
Sure. Make sure there is NO play in the dizzy's center shaft.
Get a top line PU coil from NAPA. The others sell china crap that's just going to die soon.
LG
LumpyGrits is online now
post #4 of 5 Old 07-04-2013, 12:16 PM Thread Starter
spottedfrog
1979 CJ5
LG
I have 2 dizzys, the one in my current engine, and the one that came off the engine I'm rebuilding. The one that came off the rebuild has some vertical play but no play from side to side. it spins freely and the bearings seem ok,
should I worry about the vertical play?
post #5 of 5 Old 07-04-2013, 12:21 PM
LumpyGrits
Out of the engine some will show v'play. You want "0" side play.
Make sure the advance dia. will hold vac.
LG
