Re-tuned my weber, hows it sound? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Re-tuned my weber, hows it sound?
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits OPTIC ARMOR WINDOWS all sale now !!!!!!!!2003-2004 Jeep Grand Cherokee Headlight Dark Background wi
Unread 04-12-2014, 06:34 PM   #1
kovic
1983 CJ5
Hey guys I went ahead and set my weber 32/36 to baseline and readjusted it, made a couple videos.
My mixture ended up 1 3/4 ish turns out, idle screw is 1 1/2 turns in.
My issue is the secondary adjustment. I had to mess with it just a little to get my rpms up.
what do you guys think?
Thanks
[IMG][/IMG]
[IMG][/IMG]
Sorry I couldnt figure out how to put them right on the site
kov
kovic is offline   Reply With Quote
Unread 04-12-2014, 06:48 PM   #2
swatson454
swatson454's Avatar
1983 CJ7
Sounds like you did a pretty darn good job
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline   Reply With Quote
Unread 04-12-2014, 06:56 PM   #3
kovic
1983 CJ5
Thanks Swatson The engine has some shake to it, you can see it from the air intake tube, but no big stumbles.
I was only concerned with the secondary throttle plate adjustment screw, I had to move it some to get my idle up. to 650 ish rpms. Is that ok?
Thanks
kov
Unread 04-12-2014, 08:36 PM   #4
kovic
1983 CJ5
I actually tweaked it just a tad more, took it for a hard test drive, and surprisingly there was no hesitation when I smashed it and the secondary opened. It just went
Of course I let the rpms get up there before I hit it.
But I took a video, basically a sound video of the exhaust.
Am I hearing lean pops, or am I just going crazy?
thanks
[IMG]http://i989.photobucket.com/albums/af13/kovic83/th_VID_20140412_220656_438.jpg[/IMG][/IMG]
kov
Unread 04-12-2014, 10:02 PM   #5
swatson454
swatson454's Avatar
1983 CJ7
I really couldn't hear anything on my end. Tweaking the secondary plate is a pretty common band-aid but it's a slippery slope and you don't really have a large window to work with. If you want to verify your settings, pull the carb off and have a look at how much of the enrichment hole is visible below the throttle plate. More than a quarter of it and you're probably on the edge.
With your mixture screw setting, it sounds like you nailed it.
Shawn
Unread 04-12-2014, 11:50 PM   #6
kovic
1983 CJ5
Yea I feel like I got to be close, At first what I did was leave the idle screw at 1 1/2 in, never touched it. I worked with the secondary plate screw and the idle mixture. At first attempt the mixture was out 2 1/4 turns. I felt like that was a little bit over recommended, so I screw the secondary throttle plate in a tad, that way i could put the mixture screw in the recommended area.
Its got to be close, Im not sure where the secondary should be, at one point I thought someone said 1/6th turn open. Which Im not sure how many turned it takes to even start uncovering the hole. I think I am close with that though.
I may end up taking the carb off to check, im just not sure how many more removals the gasket can take lol.
kov
