Re-routing vacuum line from canister - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Re-routing vacuum line from canister
Travelling with Pets?Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!
Unread 12-20-2009, 08:48 PM   #1
pcg7384
1981 CJ7
I broke the end off my charcoal canister if you're looking down at it from the driver's side, it's the far left input. Can I re-route this line into one of the other ones with a T fitting and plug up the hole on the canister? Do I need a "new" canister? Thanks,
Phil
pcg7384 is offline   Reply With Quote
Unread 12-20-2009, 09:06 PM   #2
mcmud
1983 CJ8
Phil, without any info as to what u got, maybe.
That nipple would be for the carb bowl vent or could be read as the purge signal.
mcmud is offline   Reply With Quote
Unread 12-20-2009, 09:16 PM   #3
pcg7384
1981 CJ7
81 CJ7 258 I-6. It's the nipple that is raised above the rest on the far left side. Not sure what it actually vents to as it goes to a plethora of hoses under the carb (looks a lot like a O2 sensor but it's not). I'd like to just T it into another line and call it good, but the vacuum system on this beast is killing me...
Phil
Unread 12-20-2009, 09:16 PM   #4
mcmud
1983 CJ8
Evaporation Canister
Look in here and ID which one is broken and then let us know what carb your running.
Unread 12-20-2009, 09:29 PM   #5
pcg7384
1981 CJ7
The nipple on the far left that hooks onto the raised part of the canister
Unread 12-20-2009, 09:30 PM   #6
pcg7384
1981 CJ7
I guess that means purge signal
Unread 12-20-2009, 09:49 PM   #7
mcmud
1983 CJ8
Yep. Kinda small for a fix. I believe you might be needing a 'new' one.
You might do well posting a WTB thread or possibly one maybe for sell in the classified section.
May find help with it here; D A V E Y S J E E P S . C O M - Currently Parting 350 Salvage Vehicles & Jeeps
Unread 12-21-2009, 03:00 AM   #8
keith460
Jeep. There's Only One
keith460's Avatar
Here's a pic that you can identify with:
The vacuum port labeled "C" will go to a ported valve on your carb whether it be Weber, MC2100, or stock Rochester. I'd look to get a replacement Charcoal Canister if that vacuum nipple is broken.
There's a guy on another Jeep forum who is selling parts and I bought a T5 from him and he had a Charcoal Canister laying around too. It would work for you. He's a little hard to get a hold of sometimes but will sell for cheap.
NJ - New Jersey Cj parts - JeepsUnlimited.com Forums
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is online now   Reply With Quote
Unread 12-21-2009, 05:45 AM   #9
Mike1084
1979 CJ7
I broke one of those plastic nipples off awhile back when changing out some vacuum hoses. They get brittle and break pretty easy. What worked for me was I reamed out the hole with a drill bit a little larger than the original hole and bought a new plastic nipple. They make many different sizes, and epoxy'ed it onto the canister. Cost me about $ .25 It works and has held up so far.
I also found a write up on how someone esle did theirs.
How To: Repair Broken Vacuum Hose Nipples - Windows Live
Mike1084 is offline   Reply With Quote
