Re-geared from 2.73 to 3.54 - sounds like she's gonna blow! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Re-geared from 2.73 to 3.54 - sounds like she's gonna blow!
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! All Bilstein shocks & struts - Lowest Prices Ever and 1 Ton Heavy Duty Steering Upgrade Kit. New and Improved d
Unread 03-20-2015, 04:26 PM   #1
Colt44
Colt44's Avatar
1983 CJ7
Well I finally swapped out the OEM 2.73 gearing (Automatic trans came with 2.73 by default) for 3.54 and now it sounds like it's running at way too high an rpm at highway speed.
I've looked at all the gearing charts which show I should be running at about 2500 - 2600 rpm at 65 mph for a 3.54 on 31" tires, which is "in the green" on all the charts I can find online.
Is it just that I was so used to running at too low an rpm and so what is normal sounds too high to me, or should I be concerned, need bigger tires, etc?
Of course, they didn't put tachs on the auto models, so I guess I'll need to add one unless someone can tell me another way to check the rpms as I drive.
Suggestions, advice?
"We are all of us in the gutter...
Some of us are looking at the stars."
~ Oscar Wilde via Chrissie Hynde
Colt44 is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 04:31 PM   #2
Mr. Boh
Try this:
http://www.grimmjeeper.com/gears.html
That should give you a real good comparison from your stock with 2.73 and 235s to 3.54 with 31s.
Mr. Boh is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 05:03 PM   #3
Erik719
Erik719's Avatar
1983 CJ7
Think you answered it.
You could get a cheap on at the auto parts and just run the wires in through the window if all you want to do is check.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 05:05 PM   #4
skizriz
1978 CJ7
I have 4.88's with a 3 speed auto. At 55mph it sounds like the valves are going to shoot out through the hood. lol
78 CJ7.. 258.. TH400/Dana18.. SOA/stock YJ springs.. 35" General Grabbers.. Waggy 44s.. 4.88 gears...Spartan/Lockright...Fiberglass front to rear
skizriz is online now   Reply With Quote Quick reply to this message
Unread 03-20-2015, 07:04 PM   #5
Colt44
Colt44's Avatar
1983 CJ7
According to grimmjeeper, here is what the RPM would be for each gear ratio.
So, at 65 mph I'm running 571 rpm higher now than before; no wonder it sounds so high to me now.
Obviously I was running at a too-low engine speed before, so I need to get used to "the new normal." (Apologies to Obama)
What's a normal cruising rpm for the 258-6? Is 2500 rpm at 65 mph about right?
Screenshot from grimmjeeper; obviously 3.54 numbers at top and 2.73 below.
Unread 03-20-2015, 07:25 PM   #6
Colt44
Colt44's Avatar
1983 CJ7
Hmm... could I just yank one from a junkyard donor like a Wrangler or Cherokee?
Unread 03-20-2015, 08:58 PM   #7
CoryA
Your also assuming your 31" tires are 31" tall try actually measuring them with a tape measure and then run the calculator
CoryA is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 09:10 PM   #8
captkhaos
1980 CJ7
They put tachs in Laredos with automatics. Ask me how I know.
captkhaos is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 10:14 PM   #9
Cutlass327
Cutlass327's Avatar
1978 CJ5
Hmm.. my old Sunpro must be off - I'm running 3k at 70MPH with 1.5 year old BFG ATs, 3.54s, and T177.
Rick
1978 CJ5 258/T177/D300, '86 D30/D44 WT axles, 'glass tub windshield frame, and fenders, 31x10.5 BFG A/T, TDK galv'd frame - DD and weekend toy
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is online now   Reply With Quote Quick reply to this message
Unread 03-20-2015, 11:23 PM   #10
jeepdaddy2000
1971 CJ5
Buy a tach. You can't do gearing work without one.
Most universal aftermarket tachs have separate settings for 4, 6, and 8 cylinder motors. The rear cover needs to be taken off to access the switch. If the switch isn't in the right place, the tatch won't read the proper RPM's (you probably knew this).
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 03-21-2015, 05:54 AM   #11
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The sweet spot for the 258 is around 2300 rpm. You will drink a lot of gas turning 2600+.
For sure those gears could take 33's.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
Unread 03-21-2015, 07:18 AM   #12
HackFabrication
1976 CJ5
Turn up the stereo.....
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote Quick reply to this message
Unread 03-21-2015, 07:22 AM   #13
swatson454
swatson454's Avatar
1983 CJ7
Mine sounded like an old prop plane ready to take flight until I installed a fan clutch.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now   Reply With Quote Quick reply to this message
Unread 03-21-2015, 07:30 AM   #14
Mike Romain
Shawn
Mine has the fixed fan and yes she sure roars.
Mike
Unread 03-21-2015, 07:44 AM   #15
WindKnot
WindKnot's Avatar
1977 CJ7
Think of it as loud pipes on a motorcycle! Mine roars too.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration? http://www.jeepforum.com/forum/f8/ph...ation-1807257/
WindKnot is online now   Reply With Quote Quick reply to this message
