Re 4.5 cj pic request - Page 2 - JeepForum.com
post #16 of 45 Old 01-11-2011, 11:14 AM Thread Starter
somfukinguy
1981 CJ8
Thanks mavsfan001 great pics and great rig. Any complaints?aq
somfukinguy is offline
post #17 of 45 Old 01-11-2011, 11:46 AM
aero mech
aero mech's Avatar
1980 CJ7
Originally Posted by somfukinguy View Post
Aero that rig is really super clean. It seems like everyone is doing the one inch body lift and 35's..except kponytail. How's the 33's feel on your 5 kponytail?
Thanks, It isn't so clean anymore with several trips to different orv parks but thats what I built it for. Its down right now for wide track axles and a rebuild on the T176, 258 with TBI and 4.o head. FWIW I like the looks of my 35's better, but I ended up installing a 4to1 kit because of the added strain. I will say I have trouble with my front shackles killing the upper bushings. I plan on installing the heavy duty wide hangers and using no lift yj shackles. But to totally change the subject if I did it over again I think I would go genright front fenders, rear crush corners with steel rear flares and the 2.5 RE YJ lift. I have nearly flopped it numerious times. The elevation of 4.5 and narrow track axles seems abit top heavy for some off camber situations JC
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline
post #18 of 45 Old 01-11-2011, 12:03 PM
mavsfan001
1983 CJ7
No complaints yet everything fit well and it rides great!!! I did have to use deg. shims on the front end to get it to drive straight down the road at high way speed. Would like to go back and cut the perches and reposition them at the corect caster angle after the springs get completly broke in and settle. My biggest problem now is i am about to re-gear and having trouble deciding if i want to go 4:10 or 4:56 ratio?
mavsfan001 is offline
post #19 of 45 Old 01-11-2011, 01:24 PM
HighFive
1981 CJ5
Originally Posted by MoC View Post
36's with 4.5" RE and 1" daystar body lift
Real Nice! Looks tough!
[/color]
Let's go Flyer's!!!!!!
HighFive is offline
post #20 of 45 Old 01-11-2011, 03:14 PM Thread Starter
somfukinguy
1981 CJ8
Aero, I lucked out and have the widetrac axles in mine. I actually got really lucky and found a stock Dana 44 out of a 86 cj, that I am going to swap in also. I have heard the yj springs make a big difference, and I think the yj hangers are not that pricey....I wonder how different the re4.5 yj kit is from the cj? If I only had to mount some new hangers that might not be bad idea, I just don't know if the brakelines and other parts with it match up.
post #21 of 45 Old 01-11-2011, 04:40 PM
aero mech
aero mech's Avatar
1980 CJ7
I actually think the springs are the same. the front shackels would be straight for the yj instead of using the conversion shackles that RE includes for the CJ. Might compare on their web site or give them a call. One more thing if they haven't chaged it the kit ships with crappy POS aluminum spring shims. Do not use them!!! It has been said before on this forum but they will bent and your u bolts will work loose and your axle will slip on the springs. Ask me how I know. All in all it is still one of the most complet kits for the $$.
Also there are places that sell the kit for less $$ than 4wd or Quad. I had a place saved in my other computer that just drop shipped items for way less money JC
post #22 of 45 Old 01-12-2011, 05:16 AM Thread Starter
somfukinguy
1981 CJ8
Yea I'm definitely going to go steel shims, I think the best price I found on the 4.5 cj kit is 1089 shipped. I may call re and ask about the yj stuff to see if I could make it fit, it just seems like it would make more sense for a little extra work and money
post #23 of 45 Old 01-12-2011, 06:21 AM
GPER
1979 CJ7
RE will send you whatever you need. I got the YJ springs and bushings, then everything else were for the CJ. My aftermarket frame was set up for the YJ bushings.
GPER is offline
post #24 of 45 Old 01-12-2011, 12:01 PM
ditchdog
1983 CJ7
JC - How does it go down the road? Do you have to chase it at all? Debating a shackle reversal but going with the RE 2.5" lift YJ springs & genright fenders for sure.
'83 CJ7, 258, Howell TBI, 3" susp + 1" body lift, 33" MT/R's.
Build thread:
ditchdog is offline
post #25 of 45 Old 01-12-2011, 04:41 PM Thread Starter
somfukinguy
1981 CJ8
What makes you lean toward the 2.5and 1 inch body lift?
post #26 of 45 Old 01-12-2011, 05:03 PM
aero mech
aero mech's Avatar
1980 CJ7
Mine drives great and I did't use the tranney lowering spacers or the front shims. I'm not sure if the prvious ? is for me or you but. I think with some rear trimming and front flat fenders a person could run 35's with less lift. My 4.5 RE kit with the 1 inch body netted about 6 inches of lift. With narrow track axles it is alittle to tall for off camber wheeling. JMO JC
post #27 of 45 Old 01-12-2011, 09:09 PM Thread Starter
somfukinguy
1981 CJ8
I wonder why some guys have issues with the driveline, and some don't....I am going to go with new driveshafts. I imagine a cv joint would prob solve the driveline shimmy problem
post #28 of 45 Old 01-13-2011, 09:30 AM Thread Starter
somfukinguy
1981 CJ8
Anybody who posted pics have trouble driving onroad with this kit or feel unsafe?
post #29 of 45 Old 01-13-2011, 09:43 AM
ditchdog
1983 CJ7
The 2.5" lift was from the PO (with CJ 2" wide springs) and I put the body lift on for a little more clearance when i put in new body mounts, and so I can get to the bellhousing bolts a little easier. Eventually I will upgrade to the YJ springs, but I'm trying to keep the susp low to have a lower center of gravity, hence the flat fenders in the future.
I've just heard that they ride better with the shackle reversal, but I bet with a beefier steering setup and softer spring a lot of the stock ride would be alleviated. BTW, thats a real clean rig you've got.
Build thread:
ditchdog is offline
post #30 of 45 Old 01-13-2011, 10:32 AM
MoC
Thanks!
MoC is offline
Pic Request - Howell TBI RetiredSERE Jeep CJ Forum 5 07-26-2009 03:03 PM
pic request dblock16 Jeep CJ Forum 2 04-01-2007 09:58 AM
pic request dblock16 Jeep CJ Forum 2 02-18-2007 04:25 PM
pic request aksourdough Jeep CJ Forum 7 02-14-2007 11:03 PM
pic request dukhntr4lfe Jeep CJ Forum 0 04-14-2006 12:53 PM
