re - Page 3 - JeepForum.com
post #31 of 49 Old 02-18-2013, 11:38 AM Thread Starter
jacques25150
1982 CJ7
re
Originally Posted by JAG811 View Post
Now lets see them on the Jeep
You wishes are order: very nice afternon today and 13°;
that was the top weater to working on my car;
so I have put on an inox air scop (i have found 3 handfull of leaf under the grill, view 1)
I have change also my mirrors, and... I have mounted my new fender flares;
to make this, I have straight out the left rear fender , and the result is on the view 2,3 and 4;
that is a good result while the wheels are very good covered
jacques25150 is offline
post #32 of 49 Old 02-19-2013, 03:36 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Nice but the air scoop actually goes on the other way pointing to the windshield.
The air pressure is actually higher at the base of the windshield and flows forward towards the front of the jeep.
Just spray some water on the hood and take it for a ride, you will see what I mean.
John Strenk is offline
post #33 of 49 Old 02-19-2013, 01:47 PM Thread Starter
jacques25150
1982 CJ7
Yes, it is right, but I have made so while I will put loovered hood panels on the hood at the 2 side of central bump to refresh my turbo d engine, and in this situation, wiil the hot air go into the car: no good
post #34 of 49 Old 02-20-2013, 03:19 AM
John Strenk
1976 CJ5
I think you are asking "if you put hood vents into the hood to help cool the under hood temperature. Will this heat go into the Fresh air intake?"
I don't know.
Tape some yarn to the hood and watch which way the air flows.
Like this:
post #35 of 49 Old 02-20-2013, 12:39 PM Thread Starter
jacques25150
1982 CJ7
I don't know.
Like this:
it is exactly the same as Your second view (I have buy parts by quadratec) and it is probably necessary while a turbo is very very hot;
this heat is added at the heat of cooling system and also the intercooler: to much temperature, and this hot air do not go in the body
post #36 of 49 Old 08-09-2013, 02:43 PM Thread Starter
jacques25150
1982 CJ7
Now, I am a lonely jeep boy, so I have a little bit time to work... and some work on my jeep;
at first, at rear, I have put on an hitch and remake a new rear "glass" in plexi, while this part on the vehicle when I bought it was completely destroy
view 1: before
view 2: after
at second, forward, I have got a problem with the american turn lighte, while they was hidden by the front bumper;
I do not want put on the french Renault turning lights (in France, nobody love this lights), so I have found swiss turning lights, monted on the bumper, and I have got an other problem, while with the turbo, it is very hot under the hood, so I have mounted grills on the hood: views 3 and 4
For the original screww and bolt addict, all of these is reverse possible, while I have all the original parts, engine without turbo also
post #37 of 49 Old 08-09-2013, 03:32 PM
skizriz
1978 CJ7
Looks good. I like the old school double tube bumpers. They went out of style years ago over on this side of the pond though.
I think retro never gets old on a CJ.
Wonder If scoops on the inner fenders would push heat up and out of the engine compartment? The front fenders are a natural scoop, you would Just need to direct it into the engine Bay.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #38 of 49 Old 08-09-2013, 03:54 PM
BOISERUNNER
1979 CJ7
I thought that the CJ's in France all had the super ugly front of the fender mounted turn signals. Did your jeep come without them or are those after market fenders?
BOISERUNNER is offline
post #39 of 49 Old 08-10-2013, 01:30 PM Thread Starter
jacques25150
1982 CJ7
Yes, You have right, but all of owners put these bad turning lights out, and that the same for my car: when I have bought them, it was not turning lights on the fenders
post #40 of 49 Old 08-10-2013, 01:36 PM Thread Starter
jacques25150
1982 CJ7
I have think so also, but I will made this for my big restauration:
I will restore the fan box and made a scoop in the right fender for the intercooler;
perhaps it will be fine to made a scoop in rear direction to put the hot air due to the turbo out in the right fender:an other idee...
But today, I have seen that it is not so hot in the engine compartment: I had lower heating in the body
LOL!!!
post #41 of 49 Old 06-03-2014, 10:45 AM Thread Starter
jacques25150
1982 CJ7
any news to my car;
I had no problems since a long time but it come: see view 1
front frame member broken!!!!!
So, I have ordered a new part to J&W Wreckers and it is very top, without rust (views 2,3 and 4)
So, I want weld the global with reinforcement plates: what do You think about this? and what do You made in this situation?
Thank You very much
post #42 of 49 Old 04-29-2015, 02:23 PM Thread Starter
jacques25150
1982 CJ7
any news about my job:
you have seen my broken front cross member, but that was not the only one damage:
the side member was cracked
and the 2 components of the side member was unwelded on the uper side (more as 1 meter!!)
So have I made the following parts to fix the new front cross member
and
and I have welded the front cross member block
and the cracked side member
all was sprayed with a spécial zinc product (99% zinc), than have I welded MORE reinforcement plates
all was sprayed with zinc product again and POR15 and chassis coat
I have worked also on the front body parts: grill and fenders, while they are also any damages and the previous owner had made bad job: no more fan shroud, battery on the left fender fixed, no intercooler for the turbo, K&N filter, and all of this was not good for the engine;
so was it important to me to find the original configuration
here You can see the damage on the left fender: the weight of the battery has completely destroyed the interior of the fender
so have I cutting the bad piece and welded a patch
and after paint
the base of the grill was restored, and rust problem cleaned
I had put an intercooler few month ago, but I was not satisfied while I put them behind the radiator and that was not good for the efficience, so have I bought a new intercooler of cherokee diesel and put them on the right fender
and now is the final result
I have also replaced my hood with temporary parts, after a little job, while You are right: rust is not an option; the paint was made ON rusted iron by jeep!!!!
My original hood is also eating by rust and my lift gate also: that will be the subject of my next post!!
post #43 of 49 Old 04-29-2015, 08:21 PM
John Strenk
1976 CJ5
How does the intercooler work sitting on the fender? I usually see them in front of the radiator or someplace that air can flow through it.
post #44 of 49 Old 04-30-2015, 04:18 AM
team-green
Hello Jacques
there an AMC sticker is front right on your photo.
Can you make it an accurate picture?
I would like to use this as a template for replication.
Thanks in advance
Greetings Team-Green
team-green is offline
post #45 of 49 Old 04-30-2015, 06:43 AM
stgil
1982 CJ7
Originally Posted by team-green View Post
Hello Jacques
Thanks in advance
Hello Team-Green,
If you do this , do it twice, of course I will pay for it!
Regards,
Gilles
FULL DANA 30 REBUILD->
CJ7 LAREDO REBUILD->http://www.jeepforum.com/forum/f8/82-cj7-laredo-diesel-restoration-1179198/
stgil is offline
