rattle under front end - JeepForum.com
post #1 of 3 Old 05-25-2004, 10:33 AM Thread Starter
Help! I recently installed a new spring plate under the leaf springs on the driver's side of my Jeep (84 CJ7, 258, 4" lift). I now have a really bad rattling sound when driving. It sounds like it is comming from under the petals on the driver's side. It rattled a little before, but never this bad. Could this possibly be related to the new spring plate not being tight enough?
My steering also seems to be wandering more.
Any ideas? I'd appreciate any help.
vintagecj7 is offline
post #2 of 3 Old 05-25-2004, 01:57 PM
390fastback's Avatar
If the spring plates not tight enough, STOP DRIVING. The axel could shift and cause a total loss of control. Double check everthing and make sure everything is tight. Then start looking for other items that could be loose, without looking at it personally I can't help. Could be anything really, since it rattled a little before I would assume its not the new spring plate, but better safe than sorry.
2000 Cherokee
68 Mustang Fastback (in progress)
71 Mach 1
68 Wildcat (also in progress)
68 International 1200 4x4
78 F150 4x4 400 4spd
390fastback is offline
post #3 of 3 Old 05-27-2004, 09:54 AM
Just some advice on things to look at...I've had these problems too.
Wheel bearings, when loose can rattle on bumps and cause problems with steering control
Steering intermediate shaft, can wear a little and rattle and cause loose steering
Toe In, adjustment problems can cause steering control issues
Ball Joints (see wheel bearings above)
Tie Rods can wear and cause a "pop" and steering control issues
Shackles and spring packs could not be fully tight and also cause the problems you have listed...
I am sure that there are others too.
twmattox is offline
'82 CJ8 ghost rattle lazyguy Jeep CJ Forum 4 01-08-2009 04:24 PM
Low RPM engine rattle DT5150 Jeep CJ Forum 19 10-17-2007 11:55 PM
4 hi rattle cutter4320 Jeep CJ Forum 2 07-31-2007 01:02 PM
T4 Rattle TomasPrimero Jeep CJ Forum 2 01-06-2006 06:52 AM
Got a rattle or vibration? you might want to try this kairo Jeep CJ Forum 2 07-12-2004 08:09 PM
