Which is rarer: CJ-7 or CJ-5? - Page 2 - JeepForum.com
post #16 of 61 Old 03-06-2012, 07:49 PM
REDnBLUES
1977 CJ7
[QUOTE=aBoyAndHisCJ;13189489]But we all see YJs on the streets on a daily or weekly basis, probably owing to the fact that they were made up to '96 and fiberglass bodies.
QUOTE]
Huh....Fiberglass Bodies?
1977 CJ7 - LT1/700R4 Project
2015 JKU Rubicon Hard Rock - stock
2013 JK Sahara - gone
REDnBLUES is online now
post #17 of 61 Old 03-06-2012, 07:50 PM
EngChase
1980 CJ7
If you consider the production numbers (courtesy of Golden Hawk
1975-1983 CJ5 production: 222,926
1976-1986 CJ7 production: 379,659
And that 111,888 of these CJ7's were made after the last CJ5, (84-86) maybe there are just a few more '7' survivors.
1980 CJ7, 258, automatic TF999
EngChase is offline
post #18 of 61 Old 03-06-2012, 09:08 PM
jimdubose
1978 CJ5
the reason you see more sevens than fives is a statistical anamoly similar to the way odds change once you make a decision in a game of chance. for instance, if you have 100 ping pong balls inside of a box you cannot see inside of, and 99 of them are white and one of them is black and you are asked to, without being able to see, reach in your hand and pick out a ping pong ball. before you reach in and extract a ball, your chances are 99 to one that you will get a white ball, but once you reach your hand in and take it out, even before your look at it and reveal its color, your odds have changed to fifty-fifty, either you got it, or you ain't. same thing with the cj-5's and cj-7's..........
is than convoluted, or what?
jimdubose is offline
post #19 of 61 Old 03-06-2012, 09:19 PM
Cherokeester
Cherokeester's Avatar
1980 CJ7
Easy, CJ7 owners drive their Jeeps, CJ5 owners park them in the garage thinking they are valuable.
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's
2010 Rubicon Unlimited
1997 TJ with various enhancements
Cherokeester is offline
post #20 of 61 Old 03-06-2012, 09:29 PM
TxJeeper20
1982 CJ5
so is a rust free 8 sumthing to jump on its got a cracked block and is rough mechanicly
Victory Loves Preparation
1982 CJ-5 350TBI/AX-15
1989 Porsche 928 S4
2003 Honda VTX 1300R
2005 Infiniti G35
TxJeeper20 is offline
post #21 of 61 Old 03-06-2012, 10:31 PM
diddy2003
CJ-7s are definitely more abundant around here. CJ-5s haven't been made since 1983, I believe, and that might make some difference. I see a bunch of wide track CJ-7s, but original CJ-5s are a rarity.
diddy2003 is offline
post #22 of 61 Old 03-06-2012, 10:51 PM
BagusJeep
1981 CJ7
And don't forget the number of CJs produced increases every day, here is the Mahindra MM
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #23 of 61 Old 03-06-2012, 11:20 PM
only in a jeep cj
Absolutely, All you are buying is the frame and tub. ALL the other stuff can easily be swapped out with common CJ engines/transmissions, etc.
In the big picture of CJ worth and condition ,Rust all over is very bad, a blown engine is no problem.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #24 of 61 Old 03-06-2012, 11:28 PM
BagusJeep
1981 CJ7
Ditto, snap it up as a CJ8 will always be a resto project that people are interested in and most will pull the engine in the process and rebuild it anyway. If the tub and frame are good then it is a project.
post #25 of 61 Old 03-07-2012, 02:45 AM
jeep670
1982 CJ8
From were Im from..the cj8 is the rarest to see on the road.Im the only one who has a cj8 on island tho there's alot of cj5 an 7 roaming around in the island tho..
jeep670 is offline
post #26 of 61 Old 03-07-2012, 05:04 AM
requiembell
1983 CJ5
1983 CJ5 production run was only a little over 3000 units, which makes mine with the 4.2/T176/Dana 300 one rare beast !
requiembell is offline
post #27 of 61 Old 03-07-2012, 05:23 AM
jerryjeeper
AMC introduced E-coat and surface precoated steel in 1982 at the Toledo Plant which made a major difference in the corrosion protection and longevity of the later generation CJ-7's and CJ-8's. Even the aftermarket replacement steel bodies sold to vendors at that time were E-coated and primed at the plant. In addition the availability of replacement fiberglass bodies around that same time were readily available and relatively inexpensive alternatives for restoration. Corrosion resistance became even more emphasized in the late 80's and 90's with the introduction of the YJ. Extensive use of two sided galvanized steel and design changes to the body structure greatly enhanced the YJ and XJ from some of the historical rust issues. YJ frames and some of the late CJ's were also E-coated at the suppliers.
jerryjeeper is offline
post #28 of 61 Old 03-07-2012, 05:27 AM
teh603
1963 CJ5
I see neither on the road down here, just Wranglers. I'd argue that the 5 is still more common, but that's because I have one in the barn right now.
teh603 is offline
post #29 of 61 Old 03-07-2012, 06:50 AM
Fitch
After reading this thread I'm happy to say I've been driving my CJ5 as a daily driver the past two weeks.
I'm not going to lie though, it's been rough as hell lol.
Fitch is offline
post #30 of 61 Old 03-07-2012, 07:05 AM
noahlon
1968 CJ5
My CJ5 isn't a daily driver, mainly because I'm only abour 100 feet from work! But the closest gas station is 20 miles away, so it does see the road quite often. Off road alot, but not rock crawling!!!
noahlon is offline
cj5 , cj7
