random stalling - JeepForum.com
post #1 of 10 Old 04-11-2013, 02:49 PM Thread Starter
rutheford
1979 CJ7
random stalling
i have a 1979 jeep cj7 manual tranny with an amc 304 with 15000 miles since it was rebuilt. its been intermittently stalling mostly under load and i cant figure it out. i have a complete new exhaust. rebuilt mc2100 about a month ago. new fuel pump fuel filter dist cap and rotor timed at 5 btdc iv got new plug wires. now i have a bad cat smell but the problem was ocurring before the new cat. maybe float bowl? any input would be much appreciated thanks
rutheford is offline
post #2 of 10 Old 04-28-2013, 06:15 PM
pman
Completely cutting out like you turned off the ignition? Or slow dying?
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #3 of 10 Old 04-28-2013, 09:27 PM
Trapshooter
Disconnect the cat and see if the problem still occurs.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #4 of 10 Old 06-19-2013, 12:14 PM
rch316
1978 CJ7
Did you figure out the problem
Hi Trapshooter were you able to figure out what was wrong with your Jeep? My CJ7 is randomly stalling on me while driving down the road. It has done it twice in the past week. It will start back up within 30 seconds after stalling. Any advice would be great. Thank you!
rch316 is offline
post #5 of 10 Old 06-19-2013, 01:17 PM
Newbjeep
1972 CJ5
I had the same problem all the sudden it started stalling every ten min turned out I had a grease rag in my gas tank that would plug my sending unit
Newbjeep is offline
post #6 of 10 Old 06-24-2013, 08:06 AM
rch316
1978 CJ7
Yes it is completely cutting out like turning off the ignition while driving.
rch316 is offline
post #7 of 10 Old 06-24-2013, 09:50 AM
84bluecj
Try checking your grounds motor to body and motor to frame... An loose connection can imitate and act like your describing
84bluecj is offline
post #8 of 10 Old 06-24-2013, 08:02 PM
pman
May possibly be your ignition module going on the fritz IF its very sudden. Try using the search function on the CJ forum; Bagus Jeep has written some thorough instructions on troubleshooting the ignition components.
Over the years, I've had three things that have caused the sudden shutoff as you describe:
-ignition module
-ignition switch
-pickup coil
pman is offline
post #9 of 10 Old 06-25-2013, 12:27 PM
jimark
1979 CJ7
I had the same issue with my 79, I checked the coil it would shoot spark up but when it got warm it would just die then start up 2 min later. This went on for a month, then changed coil and issue goes away.
jimark is offline
post #10 of 10 Old 06-25-2013, 07:09 PM
skizriz
1978 CJ7
My random stalling problem turned out to be the cap for the coil. The red wire was down to a single strand of wire where the terminal was crimped on.
It would randomly shut off. Hit the key and it would start right back up again.Took me months to figure out the problem, which I noticed by sheer luck.
A bit of solder and it's as good as new.
skizriz is offline
