Random Part - JeepForum.com
post #1 of 7 Old 11-14-2011, 10:57 AM Thread Starter
Basgallj
Random Part
I need help identifying a part... I don't have any photos at the moment but I can obtain some if necessary.
My jeep is a 1984 CJ7 with the AMC I6 258 engine. The part is located directly behind (towards the rear) the Carb / Air box. It is about the size of a soda can and has a hose that connects to a line going to each of the ports on the Exhaust Manifold. The part number is AMC 322364. I have done several searches and so far no luck. It has not shown up in any of the parts catalogues that I have seen.
Does anyone have any ideas what it could be and if it is even necesary. There is a second hose coming off of it. However, the previous owner cut it off at the part and I cannot see where it would have went.
Thanks!
Basgallj is offline
post #2 of 7 Old 11-14-2011, 11:10 AM
jakeryii
1967 CJ5
charcoal canister maybee?
94 ZJ 4.0, np 249 on 31x10.50s no lift
jakeryii is offline
post #3 of 7 Old 11-14-2011, 11:12 AM Thread Starter
Basgallj
I found that. It is located on the fire wall towards the bottom on the drivers side. This is about the same height as the carb. The hoses are an inch in diameter.
Basgallj is offline
post #4 of 7 Old 11-14-2011, 12:33 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Sounds like the diverter valve for the air pump for the emissions. There would be a larger hose about an inch in diameter from the air pump to the valve, then the outlet to the air manifold to the exhaust. Mine did not have any other hoses to it, but some may have had a line that went to the catalytic convertor. There would also be a vacuum line to it from the manifold or maybe from a temp controlled vacuum switch..
Rick
Cutlass327 is offline
post #5 of 7 Old 11-14-2011, 02:20 PM
VACJ7
VACJ7's Avatar
On a '84 258 he would have the pulse air system if he still had it but I cannot think of any component the size of a coke can. I also do not follow the statement about "line going to each of the ports on the Exhaust Manifold". A picture in this case would probably be best.
Is this what you are talking about? http://home.sprynet.com/~dale02/pulseair.htm
'84 CJ-7 |
VACJ7 is offline
post #6 of 7 Old 11-14-2011, 03:26 PM Thread Starter
Basgallj
It was the Diverter Valve. Here is the diagram. Thank you all for your help. I started looking up those parts and finally found it.
Basgallj is offline
post #7 of 7 Old 11-15-2011, 05:55 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
If you end up removing all your emissions hardware, don't just throw it away. CJ owners in States which still require this hardware post in the Wanted forum looking for some or all of it from time to time. If you pull it off, list it in Classifieds and help someone out.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
258 , 6 cylinder , engine , exhaust
random stalls.... bigHeadMarine Jeep CJ Forum 23 05-09-2011 09:56 AM
Some random blinker problems... CJ8Hokie Jeep CJ Forum 5 05-19-2010 07:09 AM
Random electrics cutting out. Aduffy32 Jeep CJ Forum 1 10-21-2009 02:52 PM
Random Picture, More Appropriate for Older Jeeps Aphelion79 Jeep CJ Forum 7 06-14-2006 08:55 PM
Random Ford Part in my engine tmak504 Jeep CJ Forum 14 06-10-2006 10:08 AM
