Ran out of gas at 1/2 tank - JeepForum.com
post #1 of 10 Old 03-10-2013, 06:18 AM Thread Starter
OleBlue73
1973 CJ5
Since my refurb is done, I've been cruising and tweaking my jeep. Luckily yesterday as Ole Blue started stuttering, I was able to pull right into a gas station to fill up. I was "out of gas", but the gauge was sitting at half full. I filled it up and only took 7 gal, so the gauge is fairly correct. It started right back up and ran good as soon as the pump was primed back. Sounds like a fuel pickup issue. Anyone else experienced this? It's a brand new 15 gal MTS poly tank and their pickup/sending unit they sell. I seem to have the tank vented properly, but I'm going to let it happen again and remove my gas cap to see if it is air locking for some reason at 1/2 tank. I'll do that before dropping the tank. Thanks.
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is offline
post #2 of 10 Old 03-10-2013, 06:24 AM
CousinCJ
1983 CJ7
Keep a can of gas in the back!
CousinCJ is offline
post #3 of 10 Old 03-10-2013, 09:21 AM Thread Starter
OleBlue73
1973 CJ5
Not a solution to the issue, but will work at the point when it happens again to get me a little further...
2009 JKU, Rubicon
post #4 of 10 Old 03-10-2013, 10:24 AM
wellmax
I feel you pain,
i never trust my gas gauge, i alway write down the odometer reading when i fill up the old jeep
that way i know where i am with the gas issue.
Not hard for me as my old tractor does not have a gas gauge, so the tank level has to be checked from time to time.
I am old school, just happy that the old jeep still starts/runs and the radio still plays.
wellmax is offline
post #5 of 10 Old 03-10-2013, 06:54 PM
skizriz
1978 CJ7
When you put the sending unit in the tank, did you make sure the pickup reached the bottom of the tank?
I barely put the "sock' on the end of pickup tube, and let the bottom of the tank push it on as I drop the sending unit in.
skizriz is online now
post #6 of 10 Old 03-10-2013, 08:07 PM Thread Starter
OleBlue73
1973 CJ5
Since it was the first time putting it together, I was more interested in getting the unit sealed at the top. I believe I pushed the filter on the tube as far as it would go because I didn't want it to fall off before it set in the tank. You describe the filter as an extension of the pickup tube. Is this correct? I wouldn't think the filter would hold enough suction to allow gasoline to travel through it and not come back out before making it to the tube.
2009 JKU, Rubicon
post #7 of 10 Old 03-10-2013, 10:08 PM
arg0413
I know this is a silly question but, did you change your fuel filters?? I had this same problem due to my fuel filters clogging.. I however had an old rusty tank and not a new one link yours..
arg0413 is offline
post #8 of 10 Old 03-11-2013, 01:54 AM
BagusJeep
1981 CJ7
If you could only cram in 7 gallons your gauge is fine, it is something else.
Most likely culprit is the pickup has a hole in it or the sock, which extends the suction level down, has fallen off.
It may also be a bent pickup tube, they are easy to bend.
I make sure mine touches bottom just before the seal lands and then press down a bit.
Other issues could be holes or splits in the Hose and the Tube.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #9 of 10 Old 03-11-2013, 09:02 AM
cj5huntingrig
1974 CJ5
CJ fuel sender pickup tubes are always a little short. I had the same problem. I know this sucks but you can remove the tank, remove the sender and pull the sender back out. take the sock off and see the link below.
This is one of many possible solutions.
http://www.jeepforum.com/forum/f8/fu...oblem-1307974/
Also, if you put in an electric fuel pump (pushing pump like the Holley), it HAS to be below the usable level of fuel. I had to mount mine low on my frame rail but it still struggles to get fuel with approx. 2 to 3 gallons left in the tank.
Good luck!
Evan
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #10 of 10 Old 03-11-2013, 09:50 AM Thread Starter
OleBlue73
1973 CJ5
Good luck!
Evan
Thanks. This is just the info I was looking for.
2009 JKU, Rubicon
