Rain - Vent - Water In FloorBoard - JeepForum.com
post #1 of 20 Old 12-24-2013, 07:54 AM Thread Starter
70worm
1977 CJ5
So I took the jeep out of the garage last week and parked it in the driveway. It rained for 2 days strait. I go out to move it and I got an inch or more of water in each floorboard! I look everywhere else but no water. I thought maybe it's coming from the vent up by the hood. So I stick my hand in the defroster hole and it's wet. Does this mean the vent is stuck open? Is the vent one of those deals where if it rain don't open it or should water not leak down through the duct work even if it is open? See I have another Jeep but the vent was blowing cold air on my feet when I got it 9 years ago so my friend closed it and taped it shut. an education on how that vent operates would be greatly appreciated.
70worm is offline
post #2 of 20 Old 12-24-2013, 08:02 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Common sources for leaks behind the dash are:
1. The seal and screw holes around the cowl vent.
2. The cowl seal, especially near the windshield frame hinges.
3. The windshield seal.
It can be a nightmare to seal up all the leaks, but it can be done, if you are persistent.
Good luck,
Matt
Matt1981CJ7 is offline
post #3 of 20 Old 12-24-2013, 09:36 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Oops, it's a 77, I posted a long list of stuff but then realized it's a 77
does it have the blower motor on the inside?
John Strenk is offline
post #4 of 20 Old 12-24-2013, 09:40 AM
John Strenk
1976 CJ5
Doesn't it have a paper duct work connecting the intake to the heater Box?
Do those have a drain? can it be plugged up with spiders nest or acorns?
post #5 of 20 Old 12-24-2013, 03:12 PM
wellmax
my old 1984 leaks after heater core fix and new seal gasket on the windshield
I just keep it in the barn during rainy weather, maybe not the best fix, but its worked so far,
I hardly ever put the hard top on it anyway, so if its getting wet, then I am getting wet.
not much of a fix, but its worked for many years.
guess that is why they installed so many drain holes in the floor, plus mine has a number of added rust holes,
but it still runs good.
wellmax is offline
post #6 of 20 Old 12-25-2013, 11:47 AM Thread Starter
70worm
1977 CJ5
I replaced the duct and cleaned the heater box. It's got something that looks like a drain hose that goes through the firewall.
70worm is offline
post #7 of 20 Old 12-25-2013, 03:32 PM
LeePrather
1978 CJ5
Check what Matt posted and also check the fit of your doors...I put weatherstripping between to stop the floor from filling up
LeePrather is offline
post #8 of 20 Old 12-25-2013, 07:05 PM
AcidLamp
Cowl seal. I plugged everything six ways from sunday,and it took a new cowl seal to achieve a weather proof cab.
AcidLamp is offline
post #9 of 20 Old 12-25-2013, 07:26 PM
texasdave
texasdave's Avatar
1980 CJ7
Yes that is a drain-hose coming through the fire wall about one and 1/2 inches it is self closing which allows water out but not in. Great place for muddobbers bees and other vermin to build nests.
texasdave is offline
post #10 of 20 Old 12-30-2013, 01:50 PM Thread Starter
70worm
1977 CJ5
My drain hose is flat in the 90degree bend that goes around the heater box and out the firewall causing it to back up. I assume this happened because of 35 years of heat. Midwest Jeep Willys have them new. 77's are an oddball transition year so if I can be of help to anyone who needs feel free to PM me.
70worm is offline
post #11 of 20 Old 01-06-2014, 10:33 PM
Colt44
1983 CJ7
One thing people forget about is that the grille over the intake on the cowling is supposed to have a gasket.
You can't get them anymore but if you look at parts diagrams it's there.
I had tried everything else, including new seals for the windshield frame, etc. and even taped off everything to go through process of elimination.
I reached the point where the only thing left was the screw holes for the grille.
So, I got some cork gasket material and made one for the intake grille.
Amazingly, no more water collecting in the floor.
Probably wouldn't hurt to spend a couple bucks and twenty minutes with an exacto knife; it might fix your leak.
"We are all of us in the gutter...
Some of us are looking at the stars."
~ Oscar Wilde via Chrissie Hynde
Colt44 is offline
post #12 of 20 Old 01-14-2014, 02:24 PM Thread Starter
70worm
1977 CJ5
I got some cork/rubber today.
70worm is offline
post #13 of 20 Old 01-16-2014, 07:11 PM Thread Starter
70worm
1977 CJ5
I completely covered the vent and still wet. so I ordered a windshield gasket and the seal that goes under the windshield frame, but I think it might be leaking from a body seem under the windshield frame.
70worm is offline
post #14 of 20 Old 01-17-2014, 10:37 AM
Colt44
1983 CJ7
You do need to go through the process of elimination. I have a white Jeep, so I went out and bought a big roll of white vinyl tape, similar to electrical tape.
Then I taped off everything that could possibly leak: the joint between the hard top and the windshield frame, the whole length of the windshield frame, the hinges for same, the weld where the base of the windshield meets the cowling and the one where the cowling meets the hood panel. And I taped around and over the cowling vent. Everytime it rained, I un-taped one section and looked for water in the cab. When I got to the cowling, Bingo! Water dripping in around the cabin vent. So I checked the drain tube to make sure it was clear, and made a gasket for the grille.
I noticed that the opening in the cowling has a down-turn that fits inside the lip of the air box, so rain can't get in that way. Other than a blocked drain tube causing overflow into the cabin vent, the only other way for water to get in is through the screw holes. Fitting a gasket blocked off that pathway, and my cab is now dry.
You may discover your leak is elsewhere, but my advice is to bite the bullet and take the time to diagnose this in a systematic way.
Otherwise you may wind up spending a lot of time and money without result.
BTW - if you look on a Jeep parts diagram, it will show a gasket and a part number - but you can't buy one.
Colt44 is offline
post #15 of 20 Old 01-17-2014, 11:23 AM
Kastraelie
1977 CJ7
This intake is actually the "pool fill-port" and the proper place to connect a garden hose, fire hose, or other source of water to turn your Jeep into a pool. Jeeps came with drain plugs so you could carry large amounts of water in them. This is why they call the body a "tub."
Just some history for y'all.
Building out a Jeep is like trying to smother a fire with twenty-dollar bills. You just never have enough at once to put it out...
Kastraelie is offline
