Radio fuse keeps blowing - JeepForum.com
post #1 of 4 Old 05-13-2011, 09:27 AM Thread Starter
RipLip
1979 CJ7
OK, i know not having a radio isn't the end of the world but the reason its blowing can't be normal either. Little history here-last week I replaced my dead battery with a Optima yellow top, I also did the Team Rush upgrade, I replaced all the terminals on a lot of my ignition solenoid while I replaced all my terminals for the battery. When I started the engine (besides it was running like crap) the radio didn't turn on and I found it blew the fuse in the back. Put one in and turned the jeep on and off a couple times and it worked great. Well last night I replaced my power wire from the alternator to the solenoid because it looked like crap and I saw my voltage meter going a little crazy. When I started the jeep back up the voltage meter stayed at 14v steady but I noticed the radio blew another fuse. It seems weird to me because before I do any electrical on the jeep I disconnect the neg. side and only replace when I'm done. Is there something I'm missing?
RipLip is offline
post #2 of 4 Old 05-16-2011, 05:36 AM Thread Starter
RipLip
1979 CJ7
I know nobody replied on this but when I was tracing all the wires back i noticed the wire popped out of the female stake on that plugged into the male slot on the fuse panel. I could also see where the wire was bouncing and arcing on multiple different araeas of the fuse panel which was causing a lot of my problems. Got everything buttoned up and all is good.
RipLip is offline
post #3 of 4 Old 05-16-2011, 08:16 AM
dharmabum
dharmabum's Avatar
Good job tracking it down. I had a bunch of wiring issues mostly because of the POs wiring jobs. I ended up ripping all of his work out to save the frustration of trying to fix it.
dharmabum is offline
post #4 of 4 Old 05-17-2011, 03:47 AM Thread Starter
RipLip
1979 CJ7
Yeah i've been knocking the idea of buying one of those painless wiring kits. It might be a good winter project. I did go through and fix a bunch of crap on this issue. Thanks
RipLip is offline
My ignition fuse keeps blowing wolfe24 Jeep CJ Forum 0 12-24-2010 06:20 PM
Heater Fuse Keeps Blowing - NEED HELP! Whiplash Jeep CJ Forum 8 12-22-2006 06:54 PM
Still blowing 50AMP fuse. Help! Skrappi69 Jeep CJ Forum 22 03-15-2006 05:48 PM
Blowing 50AMP fuse Skrappi69 Jeep CJ Forum 6 03-07-2006 08:17 AM
Keep blowing wiper fuse - HELP! imtheant Jeep CJ Forum 1 01-26-2005 07:29 PM
