Radio - JeepForum.com
post #1 of 4 Old 04-15-2013, 08:47 AM Thread Starter
dj5day
1973 DJ
Radio
I'm needing to find some help in installing an aftermarket radio in my DJ. Obviously there is no radio currently so I need the wiring help! Thanks!
dj5day is offline
post #2 of 4 Old 04-15-2013, 09:21 AM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
For the basic wiring I prefer to run dedicated ground and fused power to the battery (red and black). It acts as a filter and will remove a lot of alternator and other interference. You can then use a light or multimeter to find the switched power for your (usually yellow) wire. Then just look at your radio wiring for which speaker wire go where. Just as a note, the negative terminals on most speakers is much thinner. Most auto parts stores or radio shack has the smaller audio terminals. If you try to use the big ones they almost always work loose.
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #3 of 4 Old 04-15-2013, 09:22 AM
WindKnot
1977 CJ7
I'm not 100% certain, but reasonably confident that you won't find a fuse block on your Jeep. What fuses you have are most likely inline.
Going with that, you'll most likely want to find a "switched" hot lead and splice on to it for your power. You can ground to the body, just be sure you get a good contact.
Here's a link to a 1974 CJ5 wiring diagram:http://www.offroaders.com/tech/Jeep-...74-1975-CJ.htm
EDIT That diagram DOES show a fuse block. You maybe able to tap your power from there, maybe even a provision for a radio!
My GUESS is that a CJ and a DJ shared wiring looms. Good luck!
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #4 of 4 Old 04-15-2013, 10:12 AM
Jawbox
It would help if you can take a picture of the Fuse Block. That would help us figure out if you can tap in there.
Jawbox is offline
