Radiator for SBC?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Radiator for SBC??
RuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-26-2010, 06:29 PM   #1
CherryCj7
1979 CJ7
Radiator for SBC??
I was wondering if I could use my stock radiator for a Chevy 305 swap i am planning. The radiator is currently cooling an AMC 232 but the same radiator is sold for the AMC 304 as well. So, since my radiator would work for the AMC 304 would it also be good for the Chevy 305? Thanks for the help. - Vince
CherryCj7 is offline   Reply With Quote
Unread 04-26-2010, 06:46 PM   #2
Scooter402
Depends on which side your bottom radiator hose is on...if it's on the passenger side, then you're good. If it's the driver's side, you'll need to take it to a radiator shop to have them switch it over.
Scooter402 is offline   Reply With Quote
Unread 04-27-2010, 01:41 PM   #3
CherryCj7
1979 CJ7
Thanks for the response. My budget is very limmited. Would i be able to run a longer hose from the engine to the radiator? Anyone else have an opinion if using this radiator will work?? Thanks - Vince
Unread 04-27-2010, 02:13 PM   #4
ErikEastman
I used two different diameter lengths of flexible radiator hose and an exhaust pipe reducer and hose clamps to tie them together. Works great, no leaks. You have to go from 2" to 1.5" if I remember correctly. Someday I will do it right and get a proper radiator for the SBC. I added the Contour fan and the cooling system seems to work just fine though. I can get you a picture if you like.
ErikEastman is offline   Reply With Quote
Unread 04-27-2010, 02:18 PM   #5
CherryCj7
1979 CJ7
ErikEastman, Thanks for your response. A picture would be great if you have one. Dont go out of your way though to take one if you dont. I'm glad to hear i wont have to spend another couple hundred bucks on this project. - Vince
Unread 04-27-2010, 03:17 PM   #6
ErikEastman
Here you go:
Unread 04-27-2010, 03:47 PM   #7
Redmanchew
aka Mike
Redmanchew's Avatar
1982 CJ7
check out coolflex. thats where i finally got my lower from after frankenstein'n mine 4 times. they have all kinds of lengths, great customer service, and you dont have to buy the stupid hose clamp cover for the ends if you dont want.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
http://main.nationalmssociety.org/si...al&fr_id=18331
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline   Reply With Quote
Unread 04-27-2010, 05:55 PM   #8
CherryCj7
1979 CJ7
Thanks for the pic Erik. I will look into the coolflex Redmanchew. Thanks for all of your posts. - Vince
Unread 04-27-2010, 09:07 PM   #9
jsc7002
1966 CJ5
anyone know about the 258 radiator for a 350? It would be nice not to have to buy a new one for it.
1966 Jeep CJ5
jsc7002 is offline   Reply With Quote
Unread 04-28-2010, 12:24 AM   #10
Performance
1979 CJ5
I had one fixed at a radiator shop for $25. They swapped the outlet from the driver side to the passenger side. You should check on having it fixed before you go and run all of that hose which could be a big problem at any time.
1979 Jeep CJ5 Silver Anniversary - 305ci Chevy With TH350 Trans, 268H Comp cam, 570 Street Avenger Holley, Hedman headers, Super 40 Flowmasters, 2 1/2 Rancho Lift, 15x10 Eagle Wheels, 33x12.50 Mickey Thompson Baja MTZ Tires, Custom Full Roll Cage, Line-X Interior, Custom Rock Crawler Bumpers, Bestop Trailmax Seats, Autometer Gauges, Bestop Supertop.
Webpage link: www.freewebs.com/chromed88ss
Performance is offline   Reply With Quote
Unread 04-28-2010, 12:28 AM   #11
Performance
1979 CJ5
I tried a 3 core 258 radiator that I had the inlet and outlet switched for the conversion. It did ok, but it wouldn't cool good enough out on the road. I went to a Nothern aluminum radiator that cools 4 times as good. The 258 radiator usually works good, but it just didn't for me. I would try it if you got it.
Unread 04-28-2010, 07:34 AM   #12
3S00W
Did you try just taking off your thermostat and letting it run constantly w/o restriction?
M O O S E
J E E P : the dirtiest four letter word
1980 CJ5 5.7L 2006 TJ 4.0L 1990 XJ 4.0L(RIP)
3S00W is offline   Reply With Quote
Unread 04-28-2010, 11:57 PM   #13
Performance
1979 CJ5
Yes. One of the biggest differences in the stock radiator and the Northern radiator that I have now is the stock one is a verticle flow and the Northern is a horizontal flow. The aluminum radiator just cools so much better.
Unread 04-29-2010, 06:47 AM   #14
DT5150
1983 CJ7
i bought a 3 core all aluminum cj/sbc swap radiator on ebay from a company called superior radiator. it was about half the price of a be-cool, i think it was about $260. outstanding quality and works extremely well. my temp never gets above 180*. very very pleased with it.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline   Reply With Quote
