Radiator reccomendations for the 258 - JeepForum.com
post #1 of 6 Old 08-22-2013, 08:37 PM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I am planning to replace my radiator because my current one is leaky. I have an '85 with the 258 in it. I've never installed a radiator before.
I know I want a brass radiator, probably a 2 row. What confuses me is the various dimensions: All radiators I can find for my Jeep seem to vary slightly in their listed sizes. How can I be sure that a given radiator will fit?
Right now this is my first choice:
Murray® Heat Transfer - Radiator - part 433063
It's $230 and I can get it locally at O'Reilly Auto Parts. According to their website, it has a "limited lifetime warranty" which sounds appealing. The part number also looks up as a "Vista Pro" brand over at Rockauto and a Spectrum CU583 at other places. So I don't know if it's the same part or not, or if it even matters.
If anyone can recommend a brass 3 row for under $300 that will fit correctly, I would consider that if would likely provide better cooling than a 2 row.
Anyhow, my main concern is how do I know this thing's going to fit? Or should I expect to have to make some adjustments when installing it?
Thanks!
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #2 of 6 Old 08-22-2013, 08:51 PM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
After a bit more searching, I found this at Summit Racing for $241.99:
http://www.summitracing.com/parts/PLI-433583/
It's Vista-Pro # 433583, 3 row, brass. It has a 1 year warranty but ships free and would also be tax-free which is nice.
Outlet Size: 1 1/2 in.
Core Height (in): 15.625 in.
Core Thickness (in): 2.000 in.
Core Width (in): 24.250 in.
The one in my first post has these size specs:
Core Width (In): 24-3/8 Inch
Core Height (In): 16-7/8 Inch
Core Thickness (In): 1-1/4 Inch
So the dimensions are all different which is my main concern. How do I know either one will fit correctly? Will a .75" extra thickness mean the thing is more likely to hit the fan?
Ken4444 is offline
post #3 of 6 Old 08-22-2013, 08:52 PM
BagusJeep
1981 CJ7
The radiator fits into a hole in the body and for a 258 the critical factors are that the flange be level with the back face of the radiator to give clearance to the fan blades and the holes in the flange match up to the holes in the body and radiator cowl (if you have one). Obviously the inlet and outlet need to be in the same position as before but the radiator cap, and hence the connection to the overflow bottle, can vary so be prepared to buy a new length of small diameter hose, a few bucks.
If you are in any doubt measure the spacing of the mounting holes on your old radiator. The other measurements for core size etc will vary between radiators.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 6 Old 08-22-2013, 09:30 PM
walkerhoundvm
1981 CJ8
You may remember my post a while back when I was searching for a radiator. I bought into that aluminum 3 row BS and it was a nightmare - nothing fit, the eBay seller suggested I mod my grill, the cap was in the wrong place and the outlet hose pointed the wrong direction. I somehow crammed it in, and my fan tore it a new outlet. I wound up getting a two row brass radiator from radiator.com, it fits PERFECTLY. I have an 8274 on the front, no fan cowl, and a 195* thermostat and it's been in the high 90s here all summer, and she barely gets a tick above "C."
If I had it to do over again, I'd probably listen to some of the older and wiser members here and get the original one cored.
walkerhoundvm is offline
post #5 of 6 Old 08-22-2013, 10:13 PM
only in a jeep cj
There are two main versions, HD with a shroud (offset cap) and the Center cap/ no shroud.
They are cored at different depths depending on your fan and spacer OR your fan and clutch.
Top two HERE:
https://www.radiatorexpress.com/Prod...=CJ7&year=1985
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #6 of 6 Old 08-22-2013, 10:24 PM
Skerr
I'm thinking getting your original repaired. My experience is that it costs less and it comes back to you painted, looking fresh and new. It has always been worthwhile for me.
Kerrdog
Go Fish! <*////><
Skerr is offline
