radiator questions???? - JeepForum.com
post #1 of 2 Old 03-30-2004, 03:39 PM Thread Starter
goody350s
well i finally got my 75 cj on the road,i noticed that when i get the engine up to temp.,i get some overflow out of the tube and after
some repeated warm ups i will have to add coolant to the system
i dont think that modal year had an overflow container,i think back then they just let it run out on to the ground
my question is...was it normal to have to add coolant every so often and would an overflow container help
i guess im not sure how they work. i was under the impression
that they have a dip tube in them and that lets the coolant
back into the system and that is why they have a hot and
cold level,is that correct or am i way off?
im sure i could find one that would fit somewhere.
it would sure beat the heck out of having to add coolant
all the time
thanks for any help you guys can give me.
p.s. i also noticed that after i run it awhile and dont add any coolant it wont run out the tube anymore and i checked the level and its to where you cant hardly see a level in the radiator but it doesnt overheat...just thought id add that
75 jeep cj5 project
goody350s is offline
post #2 of 2 Old 03-30-2004, 08:23 PM
OKJeepin
OKJeepin's Avatar
Might check your cap out, could have a weak spring or bad seal. My '74 doesn't have an overflow container either, came from the factory like that, I mounted and used one from the junk yard, don't remember what it came out of, but it's easy enough to find one that'll fit.
1974 CJ-5 (Rockcrawler)
2001 Grand Cherokee Laredo (Curbcrawler)
OKJeepin is offline
Radiator questions. moonpie312 Jeep CJ Forum 1 09-12-2009 12:59 AM
Radiator Hoses for AMC 360 to CJ Radiator Rollbar Jeep CJ Forum 2 04-18-2009 11:45 AM
CJ V8 Radiator/Fiberglass Front End Questions olcj Jeep CJ Forum 7 01-11-2009 10:15 AM
Newbie w/ CJ7 Radiator questions LongueCarabine Jeep CJ Forum 14 04-13-2008 06:26 AM
Do I need a Chevy Radiator or a Jeep Radiator? brice1310 Jeep CJ Forum 8 04-19-2007 07:46 PM
