Radiator Question for CJ5 - JeepForum.com
 4Likes
post #1 of 89 Old 07-27-2017, 10:53 AM Thread Starter
cj5chic
Looks like a new radiator is needed. I have a leak somewhere and its starting to look like its not a hose but the radiator itself. I think this is the original one from 1980. Fins are pretty much squished up so replacing it is probably a good idea anyway.
So my question is:
- Is there anything I need to know on what type radiator to get?
- Is this going to be too difficult for me to do myself?
- What steps are involved?
Thanks for any help you awesome Jeep guys can give!
1980 CJ5
258
T176
Manual transmission
Pretty much stock with nothing fancy
cj5chic is online now
post #2 of 89 Old 07-27-2017, 11:17 AM
cJAY904
I did this myself recently. It was not hard , you should be able to do it.
I had a chronic issue, so I did the water pump, t-stats and flushed the system at the same time. The result was great.
the one I bought was like this one: https://www.amazon.com/Champion-Cool.../dp/B0092QWZPG
The holes were not perfect, so I had to drill out the radiator bracket a small bit.
cJAY904 is offline
post #3 of 89 Old 07-27-2017, 12:37 PM
bob4703
1974 CJ5
Summit Racing is once again selling the brass/copper OEM type radiators. I bought one 4 years ago and have had zero problems with it. Nice price too.
https://www.summitracing.com/parts/s...jeep/model/cj5
Paved roads are prime examples of government over spending!
bob4703 is offline
post #4 of 89 Old 07-27-2017, 04:05 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I run the Champion aluminum, as well.
As far as procedure:
1. Drain the old one by loosening the drain-cock on the bottom.
2. Disconnect the top and bottom hoses at the radiator. Expect some residual coolant to leak out of the hoses when you pull them off.
3. Disconnect the overflow hose, if equipped.
4. Remove the four bolts holding radiator to grill, and remove radiator.
5. Install new radiator, connect hoses, and re-fill radiator with coolant.
6. Burb the system to remove all air, then top off the coolant.
It'll be a little messy, but it's not difficult.
Matt
Matt1981CJ7 is offline
post #5 of 89 Old 07-27-2017, 05:13 PM
79AMCJeepCJ5
1979 CJ5
So my question is:
1980 CJ5
258
T176
Manual transmission
Yeah, it's pretty easy actually (I have a 79), you might want to replace the upper and lower hose too, and cap.
- 'officially' you'd have to loosen the drain cock, but probably pretty crudded up, so you might as well get a good size bucket and take the bottom hose off. (the hoses usually stick on there pretty good, use a thin longer screwdriver to work them loose if you replace the hoses, taking them off the engine side is easier.
- the radiator and shroud are held on by 4 bolts, that go through some sort of clip. if you take those out, you can hang the shroud over the fan, makes it easier. At that point you can pull the radiator out (easier with the two hoses removed.)
- new radiator in, shroud back, bolts in. The hoses go on easier with a squirt of WD40 on the ends.
- fill radiator up with coolant, run the engine, with the cap off and when the thermostat opens you'll see the coolant level go down in the radiator, keep filling until the radiator is full to the top. (don't forget to have some in the overflow canister too.
- voila, happy Jeepin.
PS: oh and standard they come with a 3 row radiator, upgrading with a 4 row (just a few $$$ more) gives you better cooling, which helps at low speeds and higher altitudes.
79AMCJeepCJ5 is offline
post #6 of 89 Old 07-27-2017, 05:14 PM
Brianscj5
X3 ^^^^
I just installed a Champion radiator #Mc583 (4 Row), thanks to Matt's build (he really knows his stuff). They are a great company to deal with!
Brianscj5 is online now
post #7 of 89 Old 07-27-2017, 05:18 PM
Brianscj5
And I know everyone likes photo's
Sent from my SM-G955U using Tapatalk
post #8 of 89 Old 08-02-2017, 08:42 PM Thread Starter
cj5chic
Once again I would like to thank all you guys for your help and instruction! Its really, really appreciated!
Went to AutoZone, they want $189 for a Radiator. Its aluminum with plastic side pieces.
Summit racing has a brass/copper one for $269. And Amazon has one that's aluminum for around $155. These things aren't cheap.
Read somewhere that if they use Magnesium Chloride in your area in the wintertime for the roads that it will eat up anything aluminum. Is that right?
post #9 of 89 Old 08-03-2017, 05:31 AM
OrangeCJ-5
1978 CJ5
I went with an aluminum radiator from Engineered Cooling Products. It dropped right in but unlike the Champion radiator the nipple for the overflow tube is correctly pointed to the driver's side.
OrangeCJ-5 is offline
post #10 of 89 Old 08-03-2017, 01:54 PM Thread Starter
cj5chic
Thanks Orange, I'll check them out!
My Jeeps overflow is just a tube coming off the radiator top that's just drops down. No overflow tank or anything like that. If radiator fluid comes out the tube it simply goes onto the ground. Weird!
post #11 of 89 Old 08-04-2017, 02:03 AM
OrangeCJ-5
1978 CJ5
Only picture I have of the radiator. Mine also does not have an overflow bottle. It is not so weird. That's how it was done back then. It will burp out the extra after a couple heating/cooling cycles and then be fine.
post #12 of 89 Old 08-05-2017, 12:55 AM Thread Starter
cj5chic
Nice clean looking engine bay! I'm jealous!!
post #13 of 89 Old 08-05-2017, 06:48 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I thought I read someplace that if you do not have a recovery tank you need to run a different type of radiator cap.
John Strenk is offline
post #14 of 89 Old 08-05-2017, 04:25 PM Thread Starter
cj5chic
My 80 CJ5 did not have a reservoir tank and it has not been an issue. However, this is what I've learned over the many years owning this Jeep:
If I fill the radiator to the top while its cold, once reaching operating temperature the fluid will run from the hose.
I always keep the fluid a couple inches from the top even though it may look low to someone else.
By doing the above mentioned, I've never had any fluid run out onto the garage floor. But there is plenty of oil on the floor!
One guys answer to no factory installed fluid reservoir.
Thought you guys would get a kick out of this!
post #15 of 89 Old 08-06-2017, 01:56 PM
OrangeCJ-5
1978 CJ5
New picture for you
