radiator question - JeepForum.com
post #1 of 5 Old 05-21-2003, 09:46 PM Thread Starter
jeepster18_88
radiator question
I need a new radiator for my '85 CJ7. It has a 258 with a 2 row radiator. What is the difference in mine and the 3 row? What are the reasons that they can't interchange?
Will it not bolt to my grill?
Are the inlet and outlet holes different?
Is the 3 row to thick?
What would I have to do to make the 3 row work?
Thanks for any and all responses!
Josh
jeepster18_88 is offline
post #2 of 5 Old 05-22-2003, 02:35 AM
blackdog
Josh,
I just went through this. I went from a
two core to a three core. The three
core will fit no problem. I also have
an 85 and the problem is that
the 85 model came with two different
radiators that mount differently.
When you call to order your new
radiator they will ask you which
side the fill cap is on. If your fill cap
is on the driver's side, you have the
odd man out radiator like I did. If this
is the case, you will unfortunately
have to pay a little more for the
radiator simply becuase they don't
make or sell as many as the normal
CJ radiator. If you are trying to find
an old one or buy a used one, make sure
the filler cap is on the same side as
your current radiator or you may run
into mounting issues.
good luck, my new 3 core works great@!
Mike
________________
85 CJ-7, 258 MPI
blackdog is offline
post #3 of 5 Old 05-22-2003, 10:01 PM Thread Starter
jeepster18_88
Thanks. Where did you get yours from? Everyone that I talked to at radiator shops or catalog sales has said that the 3 row wouldn't work? The only differences that I could find were the dimensions and cap location. They both use the same hoses so they must have the inlets and outlets in the same place. As far as I could find, Jeep only used one core support, so they must have the same mounts. Also every core support that I've seen has indentions both in the middle and on the drivers side for the radiator cap. One other difference is that they use different fan shrouds, which could cause it to not cool. If getting the right fan shroud is the only problem, then why doesn't anyone just tell you that in order to use the 3 row then you must also get the shroud for it. Oh, where did you find a 3 row with the cap on the driver's side. No one that I've talked to has one. They say that the cap is in the middle on theirs. Again, Thanks!
Josh
post #4 of 5 Old 05-22-2003, 10:38 PM
Jwhit
Jwhit's Avatar
My jeep runs with a three core radiator. I converted mine from the old two core. There isnt anything to worry about with changing it. I dont think they would have made the three core for the cj if it wouldnt work that doesnt make much sence for the manufactures. Besides doesnt the thermostat regulate the temp in the radiator??
'85 CJ7 Rebuilt 258/T5/Dana 300 Mopar MPI fuel Injuection kit - 35" Pro Comp X-Terrains,one piece rear axle, 4.56 gears, Tracloc rear, Detroit Nospin front, 2" Full-Traction Shackle Reversal, 1" body lift, 2.5" Sky Jacker lift
'05 Jeep "Willys" ~stock... daily driver
Jwhit is offline
post #5 of 5 Old 05-22-2003, 10:57 PM
blackdog
I got my 3 core with the fill cap on the drivers side from www.radiatorexpress.com. I was told
that the mounts are actually different
for the drivers side filler cap. These guys
have both. Mine had the drivers side
filler cap and I bought the drivers side
filler cap model and it fit in fine. Other
than the mounting, the drivers side filler cap model is 1" taller than the center filler cap model. One more inch of water can only help!.
Mike
__________
85 CJ-7, 258 MPI
blackdog is offline
Radiator Question for a 86 CJ7 brovo1 Jeep CJ Forum 0 11-12-2009 01:10 PM
Radiator Question hillie4life Jeep CJ Forum 4 06-09-2009 09:41 AM
radiator question ceejaysvn Jeep CJ Forum 4 05-05-2009 10:26 PM
Radiator fan question farmer-dave Jeep CJ Forum 9 03-12-2008 12:16 PM
radiator question longlimb Jeep CJ Forum 5 11-17-2005 09:28 PM
