Radiator Fitment / Gap between radiator and front grill - JeepForum.com
post #1 of 24 Old 10-10-2011, 05:28 PM Thread Starter
GlennLever
GlennLever's Avatar
One of the upgrades I did/installed this weekend was a SPECTRA PREMIUM Part # CU583 15-7/8" Between Tanks; Heavy Duty Cooling Radiator.
I installed it and noticed that there is quite a gap between the radiator and the front grill.
I checked the old radiator and it fit just the same (it was a standard radiator with only two rows).
The outside dimensions of both radiators are the same.
I had also purchased a fan shroud, but when I went to install it, it did not fit by the amount of the gap that is in front of the radiator. In other words if the radiator was forward by the amount of gap that is in front of the radiator the shroud would fit.
I could modify this radiator to move it forward, but before I do that I would like to see some pictures of other (1984 CJ-7) Jeep radiators and the gaps between the radiator and the grill. Maybe I just need to order a different fan shroud in order to get it to fit??
One other comment is the preformed radiator hoses fir perfect. If the radiator was further forward they would not have fit as nice, particularly the lower hose.
This is the shroud that I ordered. OEM Radiator Shroud
For 81-86 Jeep® CJ 6CYL with Heavy Duty Cooling
Quadratec Part No: 51218.101
Manufacturer Part No: 17102.02
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #2 of 24 Old 10-10-2011, 06:42 PM
SJ85CJ7
I went thru the samething when I replaced my radiator, first was your radiator cap centered or offset to the drivers side? My radiator I replaced had the cap offset to drivers side and I saw that the brackets that hold the radiator to the grill were set so the radiator would sit forward so there was no gap, my new one had shorter brackets so I have the gap as you do and my fan is very close to the point I had to shim it towards the engine so it wouldn't hit.
85' CJ7, 258 I6, "Team Rush" Weber 38/MSD 6A, T-176 4-speed, twin-stick Dana 300, DANA 30 fore - AMC 20 aft with stock 2.73 gears, 31" tires, 8k winch, "Dirtworx" rear bumper/tire carrier. My Daily Drive, JustEmptyEveryPocket
SJ85CJ7 is offline
post #3 of 24 Old 10-10-2011, 06:45 PM
Bakunin
Bakunin's Avatar
I'd like to see you ditch that flex fan. Those rob you of HP and gas mileage, and if you hit a good body of water, they can shred your radiator for you.
Bakunin is online now
post #4 of 24 Old 10-10-2011, 06:55 PM Thread Starter
GlennLever
GlennLever's Avatar
I'm looking for a stock fan.
I'm not sure of the robbing of HP and mileage. The whole point of a flex fan is as the RPM's go up the fan flatens out, as you go faster there is less need to pull air through the radiator as the speed of the vehicle fources air through the radiator. As the fan flatens it takes less HP to drive it.
Glenn R. Lever
My Web Site
post #5 of 24 Old 10-10-2011, 06:56 PM Thread Starter
GlennLever
GlennLever's Avatar
The cap on the originial ratiator was also in the center.
Glenn R. Lever
My Web Site
post #6 of 24 Old 10-10-2011, 07:05 PM
mopar346
Picks up HP over a fixed fan but is not as efficeint as a clutch fan. They are a carry over from before clutch fans. They actually flaten out when revved and return to basic form at constant RPMs, not quite as much as sitting idle but fairly close. It's like a switch in the power to your alternator, it drags more when generating electricity and just works like a idler pulley when not powered up.
Careful your character's showing
mopar346 is offline
post #7 of 24 Old 10-10-2011, 08:44 PM
lucdog
lucdog's Avatar
1980 CJ5
A flex fan like mentioned sucks on the trail.
My experience, 4 wheel low, 1st gear (4 to 1) 1500 to 1600 RPM's. The fan would "flatten out", not move much air, causing temps to rise.
On the road it was fine. Changed to a clutch fan, temps don't raise.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 24 Old 10-10-2011, 09:17 PM
carnell
I'm in the same boat as you. I upgraded to a 3 row and and now I have a huge gap in the front. I had no choice but to go to a flex fan. When you find the fix, let me know!!
carnell is offline
post #9 of 24 Old 10-10-2011, 09:24 PM
Erik719
1983 CJ7
Me too. I made some pieces to cover the gap in the hopes of improving air flow. I will post some pics tomorrow.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline
post #10 of 24 Old 10-10-2011, 09:28 PM Thread Starter
GlennLever
GlennLever's Avatar
Bill
Excatly correct. That is why I am looking for a stock fixed fan. It gives up HP, but it cools much better at low speed highr RPM's.
Glenn R. Lever
My Web Site
post #11 of 24 Old 10-10-2011, 09:56 PM
spottedfrog
1979 CJ5
I believe that is the same radiator I have. My Clutch fan would not fit with it. I have a stock fixed 4 blade on it now. I'm not sure if a shroud would fit or not. the fixed 4 blade seems to move allot of air though. Also fitment with my recent power steering up grade was annoying in the hose, steering shaft and pressure line department. every thing was VERY tight.
spottedfrog is offline
post #12 of 24 Old 10-10-2011, 10:01 PM Thread Starter
GlennLever
GlennLever's Avatar
This radiator fits perfect with the gear box and P/S Hoses.
Glenn R. Lever
My Web Site
post #13 of 24 Old 10-10-2011, 10:05 PM Thread Starter
GlennLever
GlennLever's Avatar
To get a shroud to fit I may have to cut up the leading edges of the shroud.
The Shroud is an important part of the cooling of the engine.
Glenn R. Lever
My Web Site
post #14 of 24 Old 10-10-2011, 10:05 PM
BagusJeep
1981 CJ7
The rad looks about right. The rear should be flat with the metalwork that it bolts to. The shroud then bolts on to the same mounting bolts.
The shroud is not supposed to be passed in front of the fan, it should be inserted down the back then bolted on around the fan. An alternative, though fiddly, is to put on the shroud and fan in one go, but it makes it a bit more fiddly to get to the fan pulley bolts.
Have you got a picture of the shroud you are tring to fit?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #15 of 24 Old 10-10-2011, 10:11 PM Thread Starter
GlennLever
GlennLever's Avatar
I did not take a picture, wish I had. The problem with the fitment is when the shroud is placed against the radiator there is a 1/2 inch gap between the edge off it and the radiator support where it wants to be bolted.
You cannot use the same bolts that hold the radiator in place because of this gap.
Everything lese lines up including the bolt holes in the shroud. They are just a 1/2 inch away from the radiator support.
I guess I could put in some spacers to make that work, but that would allow a lot of air to be sucked around the radiator rather than through it.
Glenn R. Lever
My Web Site
Fan/radiator fitment? spottedfrog Jeep CJ Forum 7 08-27-2011 09:17 PM
question on grill and radiator swarren Jeep CJ Forum 2 08-01-2011 09:34 PM
front Grill & radiator mount kponytail Jeep CJ Forum 1 08-17-2010 08:04 AM
Radiator fitment question with photo... 243 Jeep CJ Forum 7 01-20-2009 07:09 AM
Grill adjustment / radiator install tony dz Jeep CJ Forum 22 05-28-2008 07:37 PM
