Rabid Vibrations!! - JeepForum.com
post #1 of 11 Old 08-28-2011, 03:00 PM Thread Starter
Darrin29
1980 CJ5
Rabid Vibrations!!
Im new to the site. have a question as im not much of a mechanic.
over the course of a couple days ive had a minor vibration turn into a violent one. Shook my mirror off! Where should I start? The vibration is load dependent. free wheel, no problem. I realize this is probably common knowledge to most. thanks for any help.
Darrin
Darrin29 is offline
post #2 of 11 Old 08-28-2011, 03:17 PM
Mike Romain
If it is not in the steering wheel, then I would be blocking the wheels, putting it in neutral and go under to shake and twist the rear driveshaft expecting to find slop at a u-joint.
If in the steering strong, then I would have someone turn the steering wheel side to side while I was under the front looking for a moving part that has slop or up and down movement.
Mike
Mike Romain is offline
post #3 of 11 Old 08-28-2011, 03:31 PM
trj1393
could it be the legendary Jeep Death Wobble???
trj1393 is offline
post #4 of 11 Old 08-28-2011, 07:04 PM
gojeepin
1983 CJ7
Beside the info you gave us about it being load dependent, there are several things we need to know to help.
Does it occur at all speeds?
Do the wheels wobble?
Do you feel it in your seat/feet or is it in the steering column?
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #5 of 11 Old 08-29-2011, 04:57 AM Thread Starter
Darrin29
1980 CJ5
Hi and thanks. It is worse at 30-40 mph. Smooths a bit at higher speeds. I feel it in the steering column. The wheels don't wobble and when you let off the gas it stops.
Thanks guys
Darrin29 is offline
post #6 of 11 Old 08-29-2011, 06:00 AM
gojeepin
1983 CJ7
Are your front hubs unlocked?
It sounds like your front driveshaft... you don't have the transfer case in 4-wheel high do you?
BTW... my son's moving to Penscola in mid-September...
gojeepin is offline
post #7 of 11 Old 08-29-2011, 07:55 AM Thread Starter
Darrin29
1980 CJ5
No, hubs aren't locked. I'm gonna have someone look at it for me today. Tell your son to hit me up when he gets here. Few good jeep spots around.
Bogs and boulders. Great park about an hour away. Look at the website.
Darrin29 is offline
post #8 of 11 Old 08-29-2011, 08:23 AM
zeronight
1982 CJ7
Take a look at this . i had vibes just like your describing and here is what i did to fix it.
good luck
http://www.jeepforum.com/forum/f8/da...-yoke-1244355/
zeronight is offline
post #9 of 11 Old 08-29-2011, 09:04 AM
Noplainsdrifter
1974 CJ5
My money would be on bad u-joints!
It's a Jeep Thing, Chrysler Doesn't Understand!
Noplainsdrifter is offline
post #10 of 11 Old 08-29-2011, 11:43 AM
gojeepin
1983 CJ7
That's why i asked if he felt it in the feet/seat. That's usually where a rear driveshaft imbalance is felt.
Since the vibration is tied to driveline load, it's driveshaft related. Unless pinion and transfer case angles have been changed, I'd recommend checking the u-joints too.
gojeepin is offline
post #11 of 11 Old 08-29-2011, 05:27 PM Thread Starter
Darrin29
1980 CJ5
U JOINTS!!! ding ding!!! You guys are right, I'm stupid, but learning and thankful for the advice.
Darrin
Darrin29 is offline
vibrations Quazi Jeep CJ Forum 1 12-22-2010 08:34 PM
Vibrations! kyle1228 Jeep CJ Forum 44 04-28-2010 06:00 PM
Driveline Vibrations fatterman Jeep CJ Forum 4 12-14-2007 12:07 AM
more vibrations calcallender Jeep CJ Forum 9 06-11-2007 03:00 AM
Vibrations 81CJ7Renegade Jeep CJ Forum 2 01-28-2006 04:23 PM
