R&R 20 gal plastic tank on 85 CJ7 - JeepForum.com
post #1 of 9 Old 06-19-2002, 09:58 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Arrow R&R 20 gal plastic tank on 85 CJ7
I'm looking for a write up on this procedure. I need to replace the filler and vent hoses and replace the sending unit. Parts will be in hand tomorrow.
Thanks
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #2 of 9 Old 06-19-2002, 11:01 PM
CJ7Jeff
Post
It's not all that hard. I did mine just a few weeks ago. First thing I did was to disconnect the filler and vent hoses. You can try to disconnect the fuel lines to the sender through the left rear wheelwell. I opted to let the tank down a bit first, then do that. Then I put a jack under it and took the 3 bolts on the front of the skidplate and the 5 on the rear and started letting it down. Those 8 bolts are all that hold it in. Just let it down slowly and keep an eye on everything to make sure you don't get hung up on anything. The rest is pretty self explanatory. Installation is reverse of removal. Make sure you mark all of your lines when you take them off. Makes it a little easier to go back on. There are two 1/4" lines and one 3/8" line. Send me an email if you have any more questions.
'85 CJ7 258 w/Weber Carb and Nutter Bypass. Dana 44's F&R, 3.73 gears with Trac-Loc rear. Always looking for peoples $0.02.
CJ7Jeff is offline
post #3 of 9 Old 06-21-2002, 01:44 PM
jeepinbroder
Post
Are we talking about the factory option oversized plastic tank on an 85 CJ7? I think it's actually a 21.5 gal? If so, how do your skid plates look? If they are new, where on earth did you get them? If they are horribly rusted like mine, have you been able to find them anywhere? Seems like noone makes them. I work at a sheetmetal shop, so I'll be designing my own soon if I can't find one. Thanks.
85 CJ-7
jeepinbroder is offline
post #4 of 9 Old 06-21-2002, 01:58 PM
Woodbutcher100
Question
I recently put a 21.5 gallon plastic tank in my CJ5 and I have been searching high and low for a pick up tube and sending unit. It has been almost a year since it went and I just want to repace it. There is a pinhole in the float and I suppose I could solder it but I would have to get the gas out first. If I wanted to fix the hole what the hell would I do to prevent my self from turning it into an M-80 or something?
George I. Pare'
"Tonka Toy" CJ5 1980
Blacksmith
Plymouth Plantation
Woodbutcher100 is offline
post #5 of 9 Old 06-21-2002, 05:20 PM
Happypappy
Post
If it is just a pin hole soap....yes soap! will work well and seal it. Gas hardens soap and it will stay in place. There should be other sealers as well but for a pin hole in a float it should work well.
C. Lynn
Applications Engineer
Computerized Marine Diesel, IPS Systems
'06 Rubicon Unlimited
Happypappy is offline
post #6 of 9 Old 06-22-2002, 07:26 AM
Woodbutcher100
Exclamation
Wow! No kidding, just regular bar soap? I'll try it!
George I. Pare'
Blacksmith
Plymouth Plantation
post #7 of 9 Old 06-22-2002, 04:25 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
Daddy:
I don't have a write-up, but it's easy. Losen what you can, then disconnect everything Jeff is on the $ with what he said. Your tank, which as you know is 20 gallons from the factory, not 21.5, likely has so much crud in it like mine did (140,000 miles as the time), prepare to rinse it at least 3 times. Start with water, let dry real well, then use gas with Drygas to rinse.
PS - never able to get the sender just right, it's about 1/4 tank off, but at least it's consistent, and I know that 1/4 means EMPTY.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #8 of 9 Old 06-24-2002, 09:15 AM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Post
Thanks guys. CJeep is right about the tank being a factory 20 gallon. It has the factory skid plate.
As for a 22 gallon skid plate, go to the new 4WheelDrive Hardware at <a href="http://www.4wd.com" target="_blank">www.4wd.com</a> and look up part number 9502. It's $69.99. You can see it on page 119 of the new catalog. They have it in stainless steel too for $109.99
I was able to find a new 1 inch filler hose but no luck on the vent hose. It's been discontinued. I got a new sending unit and tested in outside the tank. Works great. This is the second one I bought. The first I got mail order for $26 and it was crap. Never worked! So I bought this one from my local 4WD shop, paid a little more ($40 something), and it looks like good quality stuff and works good upon test. I'm still going to run some gas out of the tank and maybe this coming weekend install it. As for the vent tube, I'll just epoxy it up if I find it all cracked.
post #9 of 9 Old 06-24-2002, 12:48 PM
jeepinbroder
Post
Thanks for the info on the skidplate, sorry for the confusion...
85 CJ-7
plastic fuel tank alisa65 Jeep CJ Forum 2 05-13-2009 03:05 PM
How to clean a plastic gas tank? spk454 Jeep CJ Forum 5 12-11-2008 12:22 PM
Plastic tank install RandyS Jeep CJ Forum 3 11-23-2006 06:45 PM
Plastic gas tank dpoliver Jeep CJ Forum 3 07-05-2002 03:09 PM
Factory Plastic Tank diamatron Jeep CJ Forum 8 01-23-2002 12:10 AM
