R&P Install- 1st hiccup-pinion nut issues - JeepForum.com
post #1 of 2 Old 01-16-2009, 09:26 PM Thread Starter
4BTCJ3A
1948 CJ3A
OK, I am starting my R&P install in my 1978 D-30 NT. They are new Yukon gears (4.10:1) with a Yukon gear master install kit. I made my set up bearings and trial assembled the pinion gear into the case.
The problem is that when I go to snug the pinion nut down (using the same thickness shim stacks (+.0005" to comp. for new bearings), the nut threads on 2 or 3 turns and then get tough to turn, eventually getting extremely hard to turn. It is to the point it feels wrong. I used a little oil on the threads, and pulled it off/out once to check things. The nut threads looked shiny, but not x-threaded. The pinion nut threads look ok (no burrs that I could see), and match the old pinion gear, but the old nut will not thread onto the new pinion gear easily (I am saving the new pinion nut for final assembly). I stopped there so I don't end up messing some expensive stuff up.
Is the pinion nut a self-locking nut? Even if it were, it is much harder to turn than other self-locking nuts I have used.
Anyone have any thoughts on this?
1948 CJ3A, In the process of a full rebuild.
4BTCJ3A is offline
post #2 of 2 Old 01-16-2009, 09:56 PM
foggybottombob
Save the new pinion nut for the last time you install it. Use the old pinion nut for the setup. The nut should spin on by hand for several turns before you have to wrench on it. The pinion nut is self locking but it is the top half of the nut that has the locking property. The first half of the nut will just spin on like a regular nut. If it does not then you have a bent thread or debris or something in the threads.
foggybottombob is offline
Issues that may occur with suspension lift install? imtheant Jeep CJ Forum 1 06-30-2008 07:47 PM
Is it hard to install Ring& Pinion and locker yourself? medunwoody Jeep CJ Forum 11 06-22-2006 09:10 PM
MC2150 Install/Idle issues Geer_hed Jeep CJ Forum 4 07-24-2005 08:48 AM
Pinion angle issues with shackle reversal hdgapeach Jeep CJ Forum 4 02-02-2005 03:23 PM
Ring & Pinion install info needed rujpn2 Jeep CJ Forum 4 06-28-2001 09:18 PM
