quick question-are the rear fender corners removable? - JeepForum.com
post #1 of 4 Old 12-03-2009, 10:33 AM Thread Starter
spittoon
I've got rust where the rear corners meet the tub. are these rear corners removable via some bolts somewhere? i see replacements for sale so i assume they are, just want to make sure whether they are bolted on or welded
spittoon is offline
post #2 of 4 Old 12-03-2009, 01:44 PM
Pathkiller
1974 CJ5
Anything is removable if you have the right tools. They are not bolted on, they are welded on with spot welds. A spot weld cutter in your drill will let you remove them for replacement.
Pathkiller is offline
post #3 of 4 Old 12-03-2009, 02:07 PM
JoonHoss
2011 JK Wrangler
yep, you just need these
Blair Spotweld Cutters
and these
12029.14 - Omix-Ada - Corner Panel Rear Passenger Side For 1976-86 Jeep CJ7 : Tellico 4x4
and some patience and time
Hoss
"three gallons of low lead; two hot dogs and a strawberry soda..."
JoonHoss is offline
post #4 of 4 Old 12-03-2009, 03:28 PM
Area.3.Fiftyone
I have the Blair Double-End Spotweld Cutter and it works really well.
I've found that if you center punch the spot weld, it makes it a lot easier to cut. The tool won't walk away as easy.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
Holes in rear corners w/ GPF rear bumper Coiz Jeep CJ Forum 1 08-29-2009 04:22 PM
Rear Corners 78treehugger Jeep CJ Forum 8 03-08-2009 08:39 PM
New Replacement Rear Cj7 Corners hold24 Jeep CJ Forum 6 12-05-2008 02:33 PM
Removable Rear Seat 1979 CJ-5 Jeep CJ Forum 1 01-29-2006 01:03 PM
quick question--rear seat Greezy Gringo Jeep CJ Forum 1 09-20-2005 10:47 AM
