Quick nuttered question - JeepForum.com
post #1 of 7 Old 02-06-2010, 04:53 PM Thread Starter
crrushing
I just bought and installed a holley 390 4bbl carb. I have already done the nutter bypass and I have set timing and all. It just doesn't seem to run great at 8* BTDC. I was wondering if I had a hose switched up on one of the vacuum ports. There is one large tube for the PCV valve and 2 small tubes, one is a full manifold vacuum source and one is a time spark vacuum source. Which one of these vacuum sourses should I hook the distributer hose to?
I also plan to do the Teamrush upgrade in the very near future.
Thanks in advance for help.
crrushing is offline
post #2 of 7 Old 02-06-2010, 10:02 PM
Pog
Pog's Avatar
Use the Spark (aka Ported) vacuum source. Also remember to set your timing while running at ~700 RPM curb idle with the disty vacuum advance line disconnected and plugged. Reconnect it after you have everything dialed in.
Pog is offline
post #3 of 7 Old 02-07-2010, 08:20 AM Thread Starter
crrushing
Thanks a lot Pog, I have set it at 8* BTDC at 1600rpm kinda like what it says under the hood. I just assumed that was the correct way to do it because i could not find anywhere that it specifically said time it at idle. And thanks for the clarification of the spark is same as ported vacuum. It is all clear now.
Thanks again
post #4 of 7 Old 02-07-2010, 01:47 PM
Pog
Pog's Avatar
Thanks again
Glad I could help. There is tons of info in these forums and some great write-ups. However, many times the small details get left out. The emissions sticker under my hood stated the same thing about setting the idle at 1600 RPM. That would be true if you had not done the Nutter. The Nutter basically reverts your ignition system to a 1980 "Pre-Emissions" setup by bypassing the ECM and moving your distributor advance from manifold vacuum advance to spark (ported) vacuum advance on the carb. As a result, you must try and duplicate how a 6-258 setup would have run in 1980 or earlier. That means setting your timing around 8* BTDC at a 700 RPM curb idle +/-20 RPM. This in itself is still not law, but just a good starting point. Many setups, especially ones that have also been "Team Rushed" can run their timing advanced up to 12* BTDC without any problems.
Mine being Nuttered and TR'ed runs great around ~9-10* BTDC with no issues.
Good luck.
Pog is offline
post #5 of 7 Old 02-07-2010, 03:29 PM Thread Starter
crrushing
I thought about something else as well. When I time it at idle at *8 BTDC do I remove and block the ported valve?
Thanks again!!
post #6 of 7 Old 02-07-2010, 04:27 PM Thread Starter
crrushing
Never mind, I reread the nutter write up and yes I will have to remove and plug the ported vacuum source. Thanks again.
post #7 of 7 Old 02-08-2010, 05:07 AM
Mike Romain
In a perfect world you shouldn't have to, but the world isn't perfect so it is safest to just unplug and block the line.
Mike
Mike Romain is offline
Team Rush ??? Nuttered??? tumbleweed58 Jeep CJ Forum 44 10-04-2011 07:56 AM
stock carb nuttered pic TACAMO Jeep CJ Forum 1 10-11-2009 08:51 PM
the scrambler is now nuttered littleturner76 Jeep CJ Forum 2 04-22-2009 08:01 PM
I am Nuttered ( WOW ) tumbleweed58 Jeep CJ Forum 4 04-11-2008 10:14 AM
fouling plugs after nuttered nichols077 Jeep CJ Forum 5 02-13-2008 06:46 AM
