Quick Jerry Can conversion to storage box - JeepForum.com
post #1 of 8 Old 09-17-2012, 09:08 PM Thread Starter
bigirons79CJ5
1979 CJ5
This was an afternoon project for me to add a little extra storage (jumper cables, tow strap, gloves, etc) for my CJ5. I started out with a jerry can purchased at a local army/navy surplus store. I was actually going to use this can for fuel, but after sand blasting, I realized it had a small rust hole in the bottom. I first sand blasted it and then used a thin cuttoff wheel on my die grinder to cut off the top. I finally killed my Harbor Freight die grinder after 4 years. I'd say I definitely got my moneys worth and will be buying another one on my next visit. After switching and using a straight die grinder, I got the lid cut off.
I installed some door edge molding and installed the hinges and front latch. Afterwards I removed the molding and front latch for prep and paint using a ceramic brake caliper paint I had left over from a previous project. After painting, I installed everything. I eventually plan on adding a thin strip of aluminum on the inside that will help guide the lid and hopefully prevent water intrusion.
I know, it's simple, but I built it for very little money.
79 CJ5 4" Skyjacker
35" Dunlop MT's, 9000lb Warn
304 built with Edelbrock cam,valve springs,timing set,intake,Holley truck avenger carb, DUI ignition, fenderwell headers w/Supertrapps, Twin Sticked D20
FOR MORE PICTURES, CHECK OUT MY PHOTOBUCKET
bigirons79CJ5 is offline
post #2 of 8 Old 09-17-2012, 09:26 PM
82JeepCJ7
1982 CJ7
I like it.
I saw this one the other day and have thought of doing the same.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 8 Old 09-17-2012, 10:01 PM
har99
1979 CJ7
Turned out really nice. I like it!
har99 is offline
post #4 of 8 Old 09-17-2012, 10:26 PM
mooncruiser
Nice job!
mooncruiser is offline
post #5 of 8 Old 09-18-2012, 08:11 AM
1SASjeepster
Bigirons,
I actually like yours better than the one with the shelves in it. You did a great job and it really adds looks and functionality to a jeep. It is sweet!
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #6 of 8 Old 09-18-2012, 08:30 AM Thread Starter
bigirons79CJ5
1979 CJ5
Thanks everyone!!
79 CJ5 4" Skyjacker
post #7 of 8 Old 08-28-2013, 01:42 PM
cocolizo
great job , really good thinking and really practical .
cocolizo is offline
post #8 of 8 Old 03-08-2014, 05:10 PM
Bullethead
Question.
I just cut mine and installed the trimming...before I install the hinges I am noticing that the bottom half is bowing out further than the top is...how did you correct this?
I'm debating installing a thin strip of aluminum to hold the bottom half sides straight.
Bullethead is offline
Jerry Can placement NV4500 Jeep CJ Forum 5 03-20-2012 12:33 PM
Jerry Can Help wingedmare Jeep CJ Forum 2 08-23-2010 12:17 AM
yj power break conversion on 76' cj (quick question) mcurcio1989 Jeep CJ Forum 7 10-12-2009 08:17 PM
Jerry Can Cleaning Q Fropleyqk Jeep CJ Forum 8 05-23-2007 04:21 PM
jerry can holders gtrpup2 Jeep CJ Forum 1 08-28-2006 10:26 PM
