Quick Help!!! - JeepForum.com
post #1 of 9 Old 03-09-2007, 06:04 PM Thread Starter
bdmonist
WTF is that?
bdmonist's Avatar
Quick Help!!!
Hey guys - Installing my new Damper on a 350 - I thought the damper should go farther on the crank than this, but looking at the timing marks, I think it may be ok, but wanted some opinions. I broke one installer already trying to get it on farther. Removed it, heated it up with boiling water and went at it again! What's your thoughts?
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #2 of 9 Old 03-09-2007, 06:10 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
Tuff one..myself i would find out whats going on with it..maybe a lil grease on thecrank snout..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #3 of 9 Old 03-09-2007, 06:15 PM Thread Starter
bdmonist
WTF is that?
bdmonist's Avatar
I oiled it up pretty good - It went on the first 1/2 inch or so fine - Initially I didn't think it was enough, but if it went any further you wouldn't be able to see the timing marks.
bdmonist is offline
post #4 of 9 Old 03-09-2007, 06:29 PM Thread Starter
bdmonist
WTF is that?
bdmonist's Avatar
That's it!
It's right guys - I took the old damper and put a new timing oil seal on it and lined up the old groove on the damper with the seal spring. Held that up to the timing cover and they were identical; SO I guess that's it. - Thanks for the input Scrambled.
bdmonist is offline
post #5 of 9 Old 03-09-2007, 09:02 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
if its fully seated it should be good..Some ballancers like that look a little off but are correct..just hard to tell online..while your at that stage you should find true tdc and compare to the balancers timing marks..
:hahaha: yj
post #6 of 9 Old 03-09-2007, 10:53 PM
Trapshooter
If I had to guess, I think your there.
The timing marks look correct.
Trapshooter is offline
post #7 of 9 Old 03-10-2007, 08:10 AM Thread Starter
bdmonist
WTF is that?
bdmonist's Avatar
Thanks - I did that while I still had the heads off. I slid the old Damper on the crank just enough to get it over the key, then made sure the TDC mark was correct and believe it or not it was I couldn't believe something finally worked out correctly!
bdmonist is offline
post #8 of 9 Old 03-10-2007, 08:44 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
You'll know for sure when you start lining the pulleys up..
BESRK is offline
post #9 of 9 Old 03-10-2007, 10:00 AM Thread Starter
bdmonist
WTF is that?
bdmonist's Avatar
You make me nervous Besrk!
bdmonist is offline
I need some quick help please! BioTex Jeep CJ Forum 3 05-15-2008 04:07 PM
Quick Help! ben8jamin Jeep CJ Forum 1 09-21-2007 08:42 AM
need a quick fix... trinic Jeep CJ Forum 1 07-01-2007 04:31 PM
Quick OBA Q collinpyle Jeep CJ Forum 8 03-30-2006 08:18 AM
Quick... awachwhiteboy Jeep CJ Forum 1 10-30-2003 12:07 AM
