Quick Carter BBL reassembly question - JeepForum.com
post #1 of 41 Old 01-02-2010, 11:53 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Quick Carter BBD reassembly question
Yesterday I 'attempted' to fix my cold idle issues using the following procedure:
Easy Fix for Jeep 258 Carter BBD Idle Problem
I followed the procedure to the T, yet the thing runs worse.
The only thing I can think of, which was not mentioned in the procedure, are the "two screws with holes in the middle of them". If I remember correctly, these screws also have a hole in the side (?)
My question is this-
Are these 'side holes' supposed to face in the same direction (toward the carb throat, I assume)?
Thanks in advance
2X
Last edited by 2Xtreme; 01-03-2010 at 06:52 AM. Reason: BBD carb, not BBL as originally posted
2Xtreme is offline
post #2 of 41 Old 01-02-2010, 10:51 PM
wrongway92407
wrongway92407's Avatar
This is a pretty straight forward repair. I remove the venturi cluster and the idle tubes I don't run anything through the tubes but cleaner and compressed air, Make sure that you don't lose the check ball. There is a factory upgrade to the idle tubes I will see if I can find it tomorrow if not maybe someone else can post it. But it involves drilling out the tube to a larger size to help prevent this problem.
Wrongway
My fleet:
86 CJ7 5.7 vortec. 4L60,D44's,OBA,Air tank bumpers w/D rings detroits,4.88,35" bfg, mt's 9500ti warn
86 CJ7 2.5 detroits, OBA 4.56, air tank bumpers, w/D rings,9500I warn 31x10.5x15, Trxus
86 CJ7 bone stock, w/factory 44 never seen the dirt soon to be for sale
87 Wrangler also never seen the dirt.
wrongway92407 is offline
post #3 of 41 Old 01-03-2010, 06:59 AM
Mike Romain
The holes in the bolts don't matter for orientation.
Most of us that go that route oversize the crimped end to 0.032" with a welding torch tip tool or a dremil tool bit which helps them not plug up.
I see more of those plug right away after a clean than I see stay cleaned because there is junk in the carb still.
I would recommend you now do the test again by watching for drips of gas to see if the fix 'held' or not.
Mike
Mike Romain is offline
post #4 of 41 Old 01-03-2010, 08:37 AM
Boodie
1961 CJ5
I used the same EXACT web page to fix my Carter CARB and it worked GREAT! Hell I even did my 4.0 Head conversion and STILL use my Carter Carb set up! I was so impressed with how well it ran after doing the "fix" that I blew off putting on my Fuel Injection!
I hope you solved your carb problem!
1961 Willys CJ-5
258 I6/4 Inch Suspension Lift/3 Inch Body Lift/2 Inch Shackle Lift/34" Tires
Boodie is offline
post #5 of 41 Old 01-03-2010, 09:24 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
9 degrees and 20mph winds today mean I am not going to be looking at it today.....
Every post I've read from people who have done that procedure state it was a simple, easy fix.
Maybe it's just me....
2Xtreme is offline
post #6 of 41 Old 01-03-2010, 09:28 AM
Mike Romain
What are you trying to fix?
When the idle tubes block, it just won't idle, period. You have to keep your foot on the gas or it dies. Even turning the idle speed screw in all the way might not be enough.
Mike
post #7 of 41 Old 01-03-2010, 11:41 AM
wrongway92407
Thanks Mike, now I don't have to go out in the wind to the garage and look that up!
Wrongway
My fleet:
post #8 of 41 Old 01-03-2010, 01:59 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
It just won't idle when it's cold. Stall at every stop and runs rough even whenon the gas.
I did manage to get it to idle somewhat, but it's a bear to get started. Once started it'll idle for a while, then die. But starts right back up no problem.
Still idles rough, but if I could get it to start I'd be a little happier. Once it turns over, I have to constantly feather the gas and it's like its running on 2 cylinders until it decides to idle on it's own...
2Xtreme is offline
post #9 of 41 Old 01-03-2010, 02:47 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Now I remember why I avoided touching carburetors like the plague.....
2Xtreme is offline
post #10 of 41 Old 01-03-2010, 02:49 PM
Mike Romain
You are now describing a choke issue and maybe a gas filter in upside down.
The gas filter has two outlets and needs to sit level, the center one goes to the carb and the top one goes to the return line. If the return line isn't up top, gas can siphon back to the tank when it sits making it real hard to start. On a hot shutdown, the vapors produced blow back to the gas tank off the top of the filter rather than vaporlocking it also.
The choke should be set with the engine warmed up. The black cover should be 2 notches rich on the mark with the plate wide open and the engine running and you put the fast idle on the second from the top step and set the rpm to 1700 or so. This sets the fast idle steps right.
Once it is warmed up, the idle mix screws can then also be set. Have those been played with?
Mike
post #11 of 41 Old 01-04-2010, 06:02 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
I was actually thinking a filter issue, too. Looking at my photos (haven't gone out to the Jeep yet) the filter is indeed upside down, as the return is on the bottom. Nor is the filter sitting level, with the outlet side sitting 10-15 degrees higher.
Was planning on replacing filter today anyway. Thanks for the info, as I would have had no idea its orientation made a difference.
Will have to look at the choke settings as you described.
The idle mix screws have not been touched. The only thing I've done other than my initial post was mess with the choke cable a little. That has been jerry-rigged by the previous owner and I am trying to figure out how it is supposed to be routed/connected/set.
I will replace the filter, look at the choke and report back this afternoon.
Thanks again
2Xtreme is offline
post #12 of 41 Old 01-04-2010, 12:15 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Sure enough, the filter was upside down, and full of crud. Replaced it properly and looked at the choke setting.
Choke appeared to be set per your instructions. I loosened it and repositioned it, just to be sure- although the notch on the cover is pretty wide. I centered it on the 2nd mark- I assume this is correct.
Played with the fast idle a little. Didn't have a timing light handy, so I winged it (wung it?).
So here is where it stands:
Starts sooner, but still wicked rough. But will remain running most of the time after stopping or goosing the gas, although acts like it is going to quit.
I assume this is progress?
2Xtreme is offline
post #13 of 41 Old 01-04-2010, 01:12 PM
Mike Romain
Sounds like it to me.
Maybe ramp up the fast idle screw a little more. When warmed up 1700 rpm is a pretty good roar. When cold that setting is supposed to keep it at 800 +/- rpm when first started cold which slowly climbs as the engine warms up.
I started my CJ a couple days ago in below freezing weather and it had been sitting for 3 months and it chugged pretty bad for a while before it finally caught like it was running on 6 cylinders instead of two... It took the second start to keep from chugging out with me not on the gas pedal, but then it did behave right. Pretty normal for a carb I think.
Mike
post #14 of 41 Old 01-04-2010, 01:36 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Well you are the wizard as far as I'm concerned, so I'll take your word for it ..... Lol.
I suppose I should probably just rebuild the thing, but I'm affraid I'd be worse off than I am now.....
2Xtreme is offline
post #15 of 41 Old 01-04-2010, 01:53 PM
Mike Romain
Ohh, but they run soo sweet after a fresh kit.... The kits are easy to put in, you just don't take apart anything you don't need to to clean it and be sure to use two wrenches on the gas line fitting. It is also the float bowl setting so has to be held with a wrench while the gas line gets tightened. That little steel chunk of gas line between the carb and filter needs a good clean also, it holds a lot of junk.
Mike
NEED CARTER YF 1 Bbl. PART QUICK! JeepHammer Jeep CJ Forum 10 12-22-2009 06:56 AM
Carter BBD question diver49 Jeep CJ Forum 4 10-07-2008 08:50 PM
Carter BBD question jrylb73 Jeep CJ Forum 4 04-12-2007 05:17 PM
Carter BBD Question! CJ7Danny Jeep CJ Forum 5 11-03-2002 05:42 PM
another carter question derm Jeep CJ Forum 2 10-03-2002 05:32 PM
