Quick brakes question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Quick brakes question
Dual Color LED Light Bars White/AmberFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/Bla
Unread 03-15-2014, 10:23 AM   #1
Kastraelie
1977 CJ7
The line for the larger reservoir connects to the front, top port on the proportioning valve, correct?
Building out a Jeep is like trying to smother a fire with twenty-dollar bills. You just never have enough at once to put it out...
My Frame-Off
Kastraelie is offline   Reply With Quote
Unread 03-16-2014, 12:04 AM   #2
crouse11c
WHAT you lost me a propreportionvalvrlydohicky!
J/K I hate brakes though.
Hopefully you are running the normal pro valve. Which has 4 holes one in front to go to front brakes. One in the rear to go to the rear brakes and two on top or bottom, I don't know how yours are mounted, both these goes to your MC the big one you speak of. I will fin a pick on line or take one tomorrow I have a cj with tub off atm.
crouse11c is offline   Reply With Quote
Unread 03-16-2014, 12:08 AM   #3
crouse11c
https://www.carolinaclassictrucks.com/Jeep-CJ-2.html
Here is the stock style, has a great photo with labels on each fitting. They seem to be different sizes going to the MC so one is 1/2 and the other is 7/16 prob so we don't put it in the wrong hole.
Unread 03-16-2014, 04:23 AM   #4
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The larger reservoir feeds the front (edit) brakes. In theory the fittings are different sized so you can't put them on backward.
Don't forget to bench bleed that master first or your next post will be about a really soft spongy brake pedal that no amount of bleeding will fix. The reservoir has to be level to do this, so it either has to be off the Jeep or you need to jack the rear up to level the reservoir. If it on a tilt, it will stay airlocked.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 03-16-2014, 07:05 AM   #5
munypit
The larger reservoir actually should feed the front disc brakes.
munypit is offline   Reply With Quote
Unread 03-16-2014, 07:20 AM   #6
Mike Romain
You are correct, it is the front one that feeds the backs.
Mike
Unread 03-16-2014, 09:01 AM   #7
WindKnot
WindKnot's Avatar
1977 CJ7
Disc brakes were an option in 1977. We don't know if this Jeep has them.
If the Jeep has disc brakes the metering valve has to be held open during the bleeding. The metering valve is on the opposite end from the rear brake outlet and has a dust cover on it.
SOME people say if you bleed the FRONT brakes first, then the rear brakes and THEN the front brakes AGAIN, you can get around this.
Paved roads are just for getting you to the starting point!
WindKnot is offline   Reply With Quote
Unread 03-16-2014, 09:22 PM   #8
Kastraelie
1977 CJ7
Guys you gave me everything I needed to know and then some!
Thanks! My jeep does have front discs btw
