Quick 360 question - JeepForum.com
post #1 of 5 Old 01-15-2002, 10:51 AM Thread Starter
Rotorhead
1982 CJ7
Post Quick 360 question
Can anyone tell me where to look for the manufacturing year stamped into the engine block on a AMC 360?
82 CJ-7- sold 😬
98 Grand Cherokee 5.9L
Rotorhead is offline
post #2 of 5 Old 01-15-2002, 11:17 PM
Crash&Burn
Post
Don't think there is one, the info is suppose to be on a tag attached to the right valve cover, good luck on that still being there!!!
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline
post #3 of 5 Old 01-16-2002, 02:58 PM
ArbLockerBoy
Post
Yes there is! The whole line of AMC V8's had it stamped near the engine mount. you may have to take the engine mount off to see it. It will say 304 or 360 or 401 right on it.
ARB Locking, OME Flexing, 6.32 creeping 79 CJ5
http://www.2trackmindoffroadclub.rockcrawler.com/
ArbLockerBoy is offline
post #4 of 5 Old 01-16-2002, 05:31 PM
Crash&Burn
Post
Locker Boy----True the displacement is cast in the block under the motor mount on each side of the block, but rotorhead asked about the year!
All my motor manuels say it's on a tag attached to the left valve cover.
post #5 of 5 Old 01-17-2002, 08:49 AM
Mackddy6
Post
I know you are looking for a year stamp...but right above where the bellhousing bolts to the block there is a block casting number...maybe you can trace that back? just a thought...hope it helps. OR...you could look at the head casting numbers, assuming they are origional heads...and compare that with a casting #s list.
Josh
Josh
'75 CJ-5 360, headers, 4 barrel, full custom cage, custom body mounts. Soon to have:FSJ D44s, 36 inch Goodyear MT/Rs, custom spring mounts, SOA, 4" lift springs, 2 inch body lift
It's better to beg forgiveness than to ask permission
Mackddy6 is offline
ANother Quick POR Question elks96 Jeep CJ Forum 3 03-30-2009 11:40 PM
Quick question... UGA6 Jeep CJ Forum 3 03-22-2008 03:33 AM
Quick cj question trombl76 Jeep CJ Forum 9 07-20-2007 12:39 PM
quick SOA question redcj576 Jeep CJ Forum 3 01-21-2007 08:21 AM
