quick 300zx brake swap question - JeepForum.com
post #1 of 8 Old 09-22-2011, 10:25 AM Thread Starter
sherlocktk
I am working on the 300zx brake swap, and I have one question, where you have the 10 inch brake line that screwes into the caliper, does it just screw in, or should there be a copper washer similar to the front CJ calipers?
sherlocktk is offline
post #2 of 8 Old 09-22-2011, 03:25 PM
SeaWulf
1983 CJ7
Mine didn't/don't have crush washers and work fine.
SeaWulf is offline
post #3 of 8 Old 01-02-2012, 12:01 AM Thread Starter
sherlocktk
I just almost finished up this project finally and I was bleeding the brakes. Where the Nissan 10 inch flex brake line attaches to the caliper it is leaking around the threads. It does not appear to be a compression fitting. How is this supposed to be sealed properly so there are no leaks
post #4 of 8 Old 01-02-2012, 07:42 AM
78FordF150
1983 CJ7
Shouldn't it have a copper crush washer between the bolt head and the steel block on the hose were they mate together?
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
78FordF150 is offline
post #5 of 8 Old 01-02-2012, 09:18 AM Thread Starter
sherlocktk
I agree there should be something and a copper crush washer is the likely solution. Is that a standard part
post #6 of 8 Old 01-02-2012, 11:44 AM
78FordF150
1983 CJ7
Take the bolt to the parts store and they should be able to find one on the shelf that fits.
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
post #7 of 8 Old 01-02-2012, 02:08 PM
batmn77
1982 CJ7
are you following a write up on doing this?
They Cant Stop Me, Even If They Stopped Me.
Car History from 1st to Present:
-1997 Mustang V6 (Sold); -1999 Chevrolet Blazer (Sold); -2001 Chevrolet Silverado Z71 (Sold); -1999 Chevrolet Z28 Camaro; 1982 Jeep CJ-7
batmn77 is offline
post #8 of 8 Old 01-02-2012, 07:48 PM Thread Starter
sherlocktk
Followed a few write ups and going to add a few pics of the ebrake cable setup as none of them seem to cover that well. None of the write ups mention a copper washer as I started my conversion with all new parts. A junk yard setup would have it installed allready. I am just making sure that's how Nissan did it
Brake Swap,quick question centralflaCJ Jeep CJ Forum 4 05-07-2008 05:20 PM
Quick V8 Swap Question -360 vs. 258- Jimthejeepman1 Jeep CJ Forum 2 01-17-2008 06:46 AM
quick question with t18 swap Bomer82 Jeep CJ Forum 8 09-03-2007 08:00 PM
quick swap question jeepvosser Jeep CJ Forum 1 03-07-2007 11:20 PM
Real quick stupid-guy brake question Fropleyqk Jeep CJ Forum 26 03-14-2005 11:45 PM
