Questions about my Weber carb installation - JeepForum.com
post #1 of 5 Old 08-15-2009, 06:51 PM Thread Starter
gmgreen
1983 CJ7
Well, I have the carb mounted, throttle cable, fuel line and 12v going to the elect choke. Do I connect the pcv valve directly to the carb and nowhere else?
Also, do I need to plug the distributor? Sorry for the stupid questions but I am going at this alone and I have never done this before. By the way it is a 34/34.
gmgreen is offline
post #2 of 5 Old 08-16-2009, 05:44 AM Thread Starter
gmgreen
1983 CJ7
Come on now, don't make me get a cattle prod out.
gmgreen is offline
post #3 of 5 Old 08-16-2009, 02:06 PM
SuB8HaVeN
The PCV on the back side of the valve cover goes into the base of the air cleaner. There should be somewhere to plug it in, and the kit should come with the hoses and everything already. The one from the front of the valve cover (with the PCV valve) should go into the baseplate adapter that comes with the Weber kit. There should be a fitting that screws into this to allow you to plug the rubber hose in. I'd use some RTV or Teflon tape on the fitting just in case to prevent vacuum leaks. As for the distributor vacuum line you need that for vacuum timing advance. This goes into the carburetor base on mine. There should be a small tube that you can plug it into for vacuum. Hope this helps...
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #4 of 5 Old 08-16-2009, 03:09 PM Thread Starter
gmgreen
1983 CJ7
Yes, it does help. I thought that the Weber instructions said to plug that connection. I must have misunderstood it. I will plug that back in. Thanks.
gmgreen is offline
post #5 of 5 Old 08-16-2009, 03:41 PM
Hank86
Hank86's Avatar
Check This thread out. I just did the weber swap and it was a flawless swap. get the holley low pressure fuel regulator 12-804 and your golden. I didn't even need to tune mine. Hope this helps you out.
http://www.jeepforum.com/forum/f8/egr-823567-post7674017/
86' CJ7 - 258 - Weber 32/36 Carb, T-5, 300 transfer case, Dana 44 rear w/ 3.31 Gears, 33" ProComp M/T on 15x10, with a 2" Body Lift, 1 1/4" shackle lift.
Hank86 is offline
More questions about weber carb problems... runs rich all the time vking76 Jeep CJ Forum 5 04-29-2010 03:01 PM
4 cyl. weber carb installation... poppatello Jeep CJ Forum 4 09-05-2008 04:09 PM
Weber Carb... CJmadison Jeep CJ Forum 10 03-14-2006 07:47 AM
Weber carb issues...Carb backfiring cjthor Jeep CJ Forum 1 10-15-2004 12:34 PM
Weber installation recommendation johny1i Jeep CJ Forum 2 12-22-2003 06:22 PM
