Question before putting timing cover back on - JeepForum.com
post #1 of 15 Old 07-13-2014, 08:53 AM Thread Starter
txhunter13
1978 CJ5
I've replaced my timing chain on my 78' CJ5 and put everything back in how it was. I've got the keys on the crank cams lined up to 6 o'clock and 12 o'clock like they should be. Am I safe to go ahead and put the cover back on? I know I will have to line up the distributor but can't I do that with the cover on? I would hate to seal up the gasket and all just to have to go back in there and take it all down again. Any help would be appreciated, thanks.
txhunter13 is offline
post #2 of 15 Old 07-13-2014, 09:31 AM
Mike Romain
You need to have the marks so the chain is on both and count the pins between the marks as a double check.
Mike
Mike Romain is offline
post #3 of 15 Old 07-13-2014, 12:23 PM
jblue1555
1979 CJ7
Beware of matching keyways. Match the timing marks on the gears.
jblue1555 is online now
post #4 of 15 Old 07-13-2014, 12:46 PM
Mike Romain
Oops, missed that. You are correct, he needs the marks on the gears to line up with each other, then put the top one at 10:00 I think it is to count the pins between marks.
Mike
post #5 of 15 Old 07-14-2014, 09:02 AM Thread Starter
txhunter13
1978 CJ5
Yes, I've got exactly 20 links between those 2 marks. About to put the timing cover back on, pretty sure I will need help with syncing the distributor!
post #6 of 15 Old 07-14-2014, 09:08 AM
gmakra
20 is not the number you need IRRC is 15
gmakra is offline
post #7 of 15 Old 07-14-2014, 09:10 AM
Mike Romain
Originally Posted by txhunter13 View Post
yes, i've got exactly 20 links between those 2 marks. About to put the timing cover back on, pretty sure i will need help with syncing the distributor!
v8?
Mike
post #8 of 15 Old 07-14-2014, 09:16 AM Thread Starter
txhunter13
1978 CJ5
Originally Posted by Mike Romain View Post
v8?
Yes, it's a V8.
post #9 of 15 Old 07-14-2014, 09:37 AM Thread Starter
txhunter13
1978 CJ5
I'm almost sure I read for the v8 that it is 20 pins from each mark, can anyone confirm this?
post #10 of 15 Old 07-14-2014, 09:45 AM
Mike Romain
Another poster just checked his V8 and he said he counted 20 pins which matches my memory of them.
Mike
post #11 of 15 Old 07-14-2014, 10:06 AM Thread Starter
txhunter13
1978 CJ5
Alright good, I know this is right. I'm about to add the timing cover back on. Is there a certain position I should leave the crank cam or anything before I seal the cover back on?
post #12 of 15 Old 07-14-2014, 10:30 AM
Mike Romain
I usually put the cover on with the bolts a bit loose, then I install the balancer to center it in the seal and tighten down the bolts I can reach to hold it. I then remove the balancer to get the rest of the bolts.
After that you will need to put your finger over #1 plug hole while turning the engine to 0 on the timing mark to verify you are on the compression, not exhaust stroke. You then can set the distributor with the rotor pointing to # 1 on the cap.
Mike
post #13 of 15 Old 07-14-2014, 11:43 AM
gmakra
Sorry me brain was stuck on the 6 cylinder.
gmakra is offline
post #14 of 15 Old 07-14-2014, 11:49 AM Thread Starter
txhunter13
1978 CJ5
If I was going to remove the oil pan, would it be best to do it now while the timing cover is off? Or is it fine to remove it after the cover is placed back on? Thank you so much for your help!
post #15 of 15 Old 07-14-2014, 01:56 PM
Mike Romain
I would do it now. It can be a pain getting that bottom seal from the bottom.
Mike
1978 , cj5 , timing chain , v8
